Hi there,
I see that the enable pin on this device can be pulled low to shut it off, and that it is pulled high on board. My question is whether there is any specific requirement on the timing of this enable signal. My idea would be to implement an extremely strong low pass filter so that it takes 1-2 seconds for the voltage to rise up to the enable voltage and turn the device on, essentially allowing the rest of the system to stabilize before this regulator is turned on. In concept, should this work as long as the timing to reach 0.4V is sufficient?
Thanks.
