Hi there,
I have a simple question.
Can this step-up voltage regulator go with 7.2 V Li-po battery? It started to burn when i connected these but im not sure where is the problem…
and this lipol:
Hi there,
and this lipol:
I am sorry you are having problems with your voltage regulator. Did you have a load connected to your regulator when it started to burn? Could you post pictures showing how you had things connected? Could you also post a picture showing the damaged area of the board?
- Grant
