I have 2 VL53L1X connected on an esp32 with 2 vibration motors.
#include <Wire.h>
#include "WiFi.h"
#include <VL53L1X.h>
// I2C pins
#define SDA_PIN 21
#define SCL_PIN 22
// XSHUT pins
#define XSHUT_LEFT 4
#define XSHUT_RIGHT 16
// Motor pins
#define MOTOR_LEFT 26
#define MOTOR_RIGHT 33
// I2C addresses
#define ADDR_LEFT 0x30
#define ADDR_RIGHT 0x31
// Thresholds
#define DISTANCE_THRESHOLD 1350 // in mm (1.2 meters)
#define VIBRATION_DURATION 1000 // 1 sec
#define MAX_PRESENCE_DURATION 5000 // 5 sec
VL53L1X sensorLeft;
VL53L1X sensorRight;
// State tracking
unsigned long lastTriggerLeft = 0;
unsigned long lastTriggerRight = 0;
unsigned long presenceStartLeft = 0;
unsigned long presenceStartRight = 0;
bool leftInZone = false;
bool rightInZone = false;
bool leftAlreadyTriggered = false;
bool rightAlreadyTriggered = false;
// Check if sensor reading is valid and in range
bool isValidReading(VL53L1X &sensor, uint16_t threshold, String direction) {
sensor.read();
Serial.print(direction);
Serial.print(": ");
Serial.print(sensor.ranging_data.range_mm);
Serial.print("mm");
return (sensor.ranging_data.range_status == 0 &&
sensor.ranging_data.range_mm < threshold);
void setup() {
delay(500);
Serial.begin(115200);
// Disable Wi-Fi
WiFi.disconnect(true); // Disconnect and erase Wi-Fi credentials
WiFi.mode(WIFI_OFF); // Turn off Wi-Fi
// Stop the Wi-Fi driver
// Disable Bluetooth
// esp_bt_controller_disable(); // Disable BT controller
// esp_bt_controller_deinit(); // Deinitialize BT controller
pinMode(MOTOR_LEFT, OUTPUT);
pinMode(MOTOR_RIGHT, OUTPUT);
digitalWrite(MOTOR_LEFT, LOW);
digitalWrite(MOTOR_RIGHT, LOW);
pinMode(XSHUT_LEFT, OUTPUT);
pinMode(XSHUT_RIGHT, OUTPUT);
digitalWrite(XSHUT_LEFT, LOW);
digitalWrite(XSHUT_RIGHT, LOW);
delay(10);
Wire.begin(SDA_PIN, SCL_PIN, 100000);
delay(10);
// === Power and init LEFT sensor ===
// digitalWrite(XSHUT_LEFT, HIGH);
pinMode(XSHUT_LEFT, INPUT);
delay(100);
sensorLeft.setTimeout(500);
if (!sensorLeft.init()) {
Serial.println("Failed to init LEFT sensor");
while (1);
sensorLeft.setAddress(ADDR_LEFT);
Serial.println("Left sensor set to 0x30");
// === Power and init RIGHT sensor ===
// digitalWrite(XSHUT_RIGHT, HIGH);
pinMode(XSHUT_RIGHT, INPUT);
delay(100);
sensorRight.setTimeout(500);
if (!sensorRight.init()) {
Serial.println("Failed to init RIGHT sensor");
while (1);
Serial.println("Right sensor set to 0x29");
sensorLeft.setDistanceMode(VL53L1X::Medium);
sensorRight.setDistanceMode(VL53L1X::Medium);
sensorLeft.setMeasurementTimingBudget(50000);
sensorRight.setMeasurementTimingBudget(50000);
sensorLeft.startContinuous(50);
sensorRight.startContinuous(50);
void loop() {
unsigned long now = millis();
// ======= LEFT SENSOR =======
bool leftDetected = isValidReading(sensorLeft, DISTANCE_THRESHOLD, "Left");
if (leftDetected) {
if (!leftInZone) {
// First time detected
presenceStartLeft = now;
leftInZone = true;
if (!leftAlreadyTriggered && (now - presenceStartLeft < MAX_PRESENCE_DURATION)) {
digitalWrite(MOTOR_LEFT, HIGH);
lastTriggerLeft = now;
leftAlreadyTriggered = true;
Serial.print(" LEFT: TRIGGERED");
if (leftAlreadyTriggered && (now - lastTriggerLeft >= VIBRATION_DURATION)) {
Serial.print(" LEFT: OFF");
if ((now - presenceStartLeft) >= MAX_PRESENCE_DURATION) {
Serial.print(" LEFT: PRESENCE CAPPED");
} else {
// No object in range
leftInZone = false;
Serial.print(" LEFT: CLEAR");
Serial.print("\t");
// ======= RIGHT SENSOR =======
bool rightDetected = isValidReading(sensorRight, DISTANCE_THRESHOLD, "Right");
if (rightDetected) {
if (!rightInZone) {
presenceStartRight = now;
rightInZone = true;
if (!rightAlreadyTriggered && (now - presenceStartRight < MAX_PRESENCE_DURATION)) {
digitalWrite(MOTOR_RIGHT, HIGH);
lastTriggerRight = now;
rightAlreadyTriggered = true;
Serial.print(" RIGHT: TRIGGERED");
if (rightAlreadyTriggered && (now - lastTriggerRight >= VIBRATION_DURATION)) {
Serial.print(" RIGHT: OFF");
if ((now - presenceStartRight) >= MAX_PRESENCE_DURATION) {
Serial.print(" RIGHT: PRESENCE CAPPED");
} else {
Serial.print(" RIGHT: CLEAR");
Serial.println();
delay(50);
Im using 12 inches wires to connect them, checked continuity, sensor has built in pull up resistor.
Error:
E (9098) i2c.master: I2C transaction unexpected nack detected
E (9103) i2c.master: s_i2c_synchronous_transaction(945): I2C transaction failed
E (9110) i2c.master: i2c_master_receive(1261): I2C transaction failed
E (9116) i2c.master: I2C hardware NACK detected
E (9120) i2c.master: I2C transaction unexpected nack detected
E (9126) i2c.master: s_i2c_synchronous_transaction(945): I2C transaction failed
E (9133) i2c.master: i2c_master_multi_buffer_transmit(1207): I2C transaction failed
E (9140) i2c.master: I2C hardware NACK detected
E (9144) i2c.master: I2C transaction unexpected nack detected
What to do? Thanks
