Hello, I enter this great community to try to solve a problem with two vl53l0x sensors and an oled 1306 screen, I explain the case, the two sensors work correctly and the oled screen shows information on the screen, the problem is that one of the sensors shows me -1, I have tried exchanging the xshut pins on the two sensors and the one that showed measurement shows -1 and the one that showed -1 measures perfectly, I have tried the two sensors without screen and they measure correctly, I have tried a sensor with the oled and it shows the measurement correctly, it is to put the two sensors and the oled and one stop measuring, I have tried different codes and it happens the same in all of them, this is the code
#include <Wire.h>
#include <VL53L0X.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 32
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define XSHUT_pin2 9
#define XSHUT_pin1 8
#define Sensor2_newAddress 0x3F
#define Sensor1_newAddress 0x31
VL53L0X Sensor1;
VL53L0X Sensor2;
void setup() {
pinMode(XSHUT_pin1, OUTPUT);
pinMode(XSHUT_pin2, OUTPUT);
digitalWrite(XSHUT_pin1,HIGH);
digitalWrite(XSHUT_pin2, HIGH);
Serial.begin(9600);
Wire.begin();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // Address 0x3C for 128x64
Sensor1.setAddress(Sensor1_newAddress);
pinMode(XSHUT_pin1, LOW);
delay(10);
Sensor2.setAddress(Sensor2_newAddress);
pinMode(XSHUT_pin2, LOW);
delay(10);
Sensor1.setTimeout(500);
Sensor1.init(true);
Sensor1.startContinuous();
Sensor2.setTimeout(500);
Sensor2.init(true);
Sensor2.startContinuous();
pinMode(13, OUTPUT);
void loop() {
int range1 = Sensor1.readRangeContinuousMillimeters();
int range2 = Sensor2.readRangeContinuousMillimeters();
Serial.print("Sensor 2 Address: 0x");
Serial.print(Sensor2.getAddress(), HEX);
Serial.print(", Range: ");
Serial.print(range2);
Serial.println(" mm");
Serial.print("Sensor 1 Address: 0x");
Serial.print(Sensor1.getAddress(), HEX);
Serial.print(range1);
// Clear the display
display.clearDisplay();
// Set text size and color
display.setTextSize(1);
display.setTextColor(SSD1306_WHITE);
// Print sensor readings on the OLED display
display.setCursor(0, 0);
display.print("Sensor 1: ");
display.print(range1);
display.println(" mm");
display.setCursor(0, 10);
display.print("Sensor 2: ");
display.print(range2);
display.display();
if (range1 <= 100 || range2 <= 100) {
digitalWrite(13, HIGH);
delay(200);
digitalWrite(13, LOW);
delay(200);
} else {
