I have a 3pi robot and ATmega 1284P and I would like to make a serial connection between them. In order to do so, I connected: VCC → VCC, GND → GND, PD0 → PD1, PD1 → PD0 of 3pi and 1284P respectively. However, serial link doesn’t work. I used a very simple code to check functionality:
// Code for ATmega 1284P
// Sends letter 'a' every second
int main()
char text[] = "a";
serial_set_baud_rate(UART0, 9600);
while (1) {
serial_send_blocking(UART0, text, 1);
delay_ms(1000);
return 0;
// Code for 3pi (ATmega328P)
// Uses polling to receive data form ATmega1284P. Prints out number of bytes
// caught and ASCII code of the character.
char receive_buffer[100];
int receive_buffer_position = 0;
void init_serial() {
serial_set_baud_rate(9600);
serial_set_mode(SERIAL_CHECK);
serial_receive_ring(receive_buffer, 100);
char serial_read_byte() {
char result;
while (serial_get_received_bytes() == receive_buffer_position) {
serial_check();
result = receive_buffer[receive_buffer_position];
receive_buffer_position++;
if (receive_buffer_position >= 100)
return result;
int main()
unsigned short number = 0;
init_serial();
while (1) {
char byte = serial_read_byte();
number++;
clear();
print_long(number);
lcd_goto_xy(4, 0);
print_long(byte);
return 0;
The expected result would be an increasing number every second together with 97 (ASCII for ‘a’). Unfortunately, all I get is a number incresing by 3 (!) every 20 seconds (!!) with a 0 ASCII code (!!!).
I spent several hours to debug it, but without success. However, I found out that when I use delay_ms() on ATmega1284P it actually takes x20 more time. I replaced it with _delay_ms() like this:
#define F_CPU 20000000UL // 20 MHz
#include <util/delay.h>
int main()
char text[] = "a";
while (1) {
_delay_ms(1000);
return 0;
And got exactly the same result. Only changing F_CPU to 1000000 (20x slower) gave me correct timing. However, serial still doesn’t work.
Here is what I tried already:
- using interrupt versions of USART receiver functions
- different baud rates (19200, 115200)
- checked my soldering
I would appreciate help!
