The TAMIYA 70168 comes with 4 available ratios, and the position of the two axles depend on the ratio you choose when building the gearbox.
What about the TAMIYA 70097? Does each motor drive its axle (as in the 70168) or there’s just one single axle driven by the two motors at the same time?
The 70097 comes with 4 ratios too, does it alter the axle position too, or it’s fixed no matter with ratio you build the gearbox to?
Thanks
