I want to build a turntable with a 40 to 50cm diameter (ca. 15-20 inch), and a load of about 1 - 2 kg.
The table should make 360° in 1 Sec. Not in a continuous rotation, but with 25 ‚stop an goes‘. Each stop should be at least 30ms (x25). So the motor should turn the 360° in 250ms, or each 14.4° in 10ms.
I’ve tried a setup with arduino, big easy driver and a stepper with planetary gear. The specs for the motor are 904 rpm, but I only managed to run the 14.4° in 30ms. Besides the whole thing is really noisy and vibrates and jumps a lot, obviously because of the fast stop and go and the centrifugal forces.
Does anyone have a suggestion, what motor to use: a stepper or would a brushless motor or servo be a better option? What driver would I need?
Thanks!
