I was able to get the failed Wixel in bootloader mode (the yellow and green LEDs were both on) when I plug in the Wixel the green light now comes on but the Wixel does not show up on the Wixel config utility and refresh does not make it show up.
Using a new Wixel for testing. I am using the following code for this test. As it is now, I am using P0_0 to control the transistor. It appears that it may be resetting the Wixel because after I load the code the wixel disappears from the config util for a half minute or so then reappears - but it may just be a delay due to config util itself.
This code does NOT flash the LED at 2 sec. intervals as expected. LED comes ON when code starts running on Wixel and never goes OFF. The voltage when the LED is ON is 3.0V at P0_0 - so that is good.
/** io_repeater app (altered for my use):
wireless capabilities not used for this test - only used a single wixel.
/** Dependencies **************************************************************/
#include <cc2511_map.h>
#include <board.h>
#include <usb.h>
#include <usb_com.h>
#include <random.h>
#include <time.h>
#include <gpio.h>
#include <radio_queue.h>
#define MAX_TX_INTERVAL 10 // maximum time between transmissions (ms)
#define PIN_COUNT 15
static uint8 CODE pins[PIN_COUNT] = {0, 1, 2, 3, 4, 5, 10, 11, 12, 13, 14, 15, 16, 17, 21};
// macros to determine whether a pin is an input or output based on its link param
#define IS_INPUT(pin) (pinLink(pin) < 0)
#define IS_OUTPUT(pin) (pinLink(pin) > 0)
// list and count of input pins
static uint8 XDATA inPins[PIN_COUNT];
static uint8 inPinCount = 0;
// list and count of output pins
static uint8 XDATA outPins[PIN_COUNT];
static uint8 outPinCount = 0;
// only tx if we have at least one input; only rx if we have at least one output
static BIT txEnabled = 0;
static BIT rxEnabled = 0;
// In each byte of a buffer:
// bit 7 = pin value
// bits 6:0 = pin link
#define PIN_LINK_OFFSET 0
#define PIN_LINK_MASK 0x7F
#define PIN_VAL_OFFSET 7
/** Parameters ****************************************************************/
int32 CODE param_P0_0_link = 0;
int32 CODE param_P0_1_link = 0;
int32 CODE param_P0_2_link = 0;
int32 CODE param_P0_3_link = 0;
int32 CODE param_P0_4_link = 0;
int32 CODE param_P0_5_link = 0;
int32 CODE param_P1_0_link = 0;
int32 CODE param_P1_1_link = 0;
int32 CODE param_P1_2_link = 0;
int32 CODE param_P1_3_link = 0;
int32 CODE param_P1_4_link = 0;
int32 CODE param_P1_5_link = 0;
int32 CODE param_P1_6_link = 0; // solenoid (LED in test) (Wixel's 3.3V signal causes transistor to switch
// which activates 6A relay that controls 12V to LED)
int32 CODE param_P1_7_link = 0;
int32 CODE param_P2_1_link = 0; // red LED
#define TRUE 1
#define FALSE 0
#define SIGNAL_RELEASE_SOLENOID_INDEX 0
void releaseSolenoid(int nDelay);
void initSignalVars();
/** Functions *****************************************************************/
void updateLeds()
usbShowStatusWithGreenLed();
LED_YELLOW(vinPowerPresent());
int8 pinLink(uint8 pin)
switch(pin)
case 0: return param_P0_0_link;
case 1: return param_P0_1_link;
case 2: return param_P0_2_link;
case 3: return param_P0_3_link;
case 4: return param_P0_4_link;
case 5: return param_P0_5_link;
case 10: return param_P1_0_link;
case 11: return param_P1_1_link;
case 12: return param_P1_2_link;
case 13: return param_P1_3_link;
case 14: return param_P1_4_link;
case 15: return param_P1_5_link;
case 16: return param_P1_6_link;
case 17: return param_P1_7_link;
case 21: return param_P2_1_link;
return 0;
void configurePins(void)
uint8 pin, tmp;
// Set all pulled pins to high
// TODO: make this user-configurable
setPort0PullType(HIGH);
setPort1PullType(HIGH);
// Port 2 is pulled low and should remain pulled low; pulling it high would cause problems.
for(pin = 0; pin < PIN_COUNT; pin++)
tmp = pins[pin];
if (IS_OUTPUT(tmp))
// This pin is configured as an output, so add it to the list of output pins.
// The default state of the output pins, as documented in the user's guide, is LOW.
setDigitalOutput(tmp, LOW);
outPins[outPinCount++] = tmp;
rxEnabled = 1;
else if (IS_INPUT(tmp))
// This pin is configured as an input, so add it to the list of input pins.
// The pin is already an input because all pins are inputs by default.
inPins[inPinCount++] = tmp;
txEnabled = 1;
// read the states of input pins on this Wixel into a buffer
void readPins(uint8 XDATA * buf)
uint8 pin;
for (pin = 0; pin < inPinCount; pin++)
// put pin link in lower 7 bits, read pin state and put in highest bit
buf[pin] = (-pinLink(inPins[pin]) << PIN_LINK_OFFSET) | (isPinHigh(inPins[pin]) << PIN_VAL_OFFSET);
// set the states of output pins on this Wixel based on values from a buffer
void setPins(uint8 XDATA * buf, uint8 byteCount)
uint8 byte, pin;
// loop over all bytes in packet
for (byte = 0; byte < byteCount; byte++)
for (pin = 0; pin < outPinCount; pin++)
// check if this output pin's link matches the link in this packet
if ((uint8)pinLink(outPins[pin]) == ((buf[byte] >> PIN_LINK_OFFSET) & PIN_LINK_MASK))
// if so, set the pin state based on the val bit
setDigitalOutput(outPins[pin], (buf[byte] >> PIN_VAL_OFFSET) & 1);
void main(void)
// pointers to link packets
uint8 XDATA * txBuf;
uint8 XDATA * rxBuf;
uint8 lastTx = 0;
systemInit();
usbInit();
radioQueueInit();
configurePins();
releaseSolenoid(2000);
delayMs(2000);
delayMs(2000);
delayMs(2000);
delayMs(2000);
initSignalVars();
while(1)
updateLeds();
boardService();
usbComService();
// receive pin states from another Wixel and set our output pins
if (rxEnabled && (rxBuf = radioQueueRxCurrentPacket()))
setPins(rxBuf + 1, *rxBuf);
radioQueueRxDoneWithPacket();
// read our input pins and transmit pin states to other Wixel(s) every MAX_TX_INTERVAL milliseconds
if (txEnabled && (uint8)(getMs() - lastTx) > MAX_TX_INTERVAL && (txBuf = radioQueueTxCurrentPacket()))
readPins(txBuf + 1);
*txBuf = inPinCount; // set packet length byte
radioQueueTxSendPacket();
lastTx = getMs();
// retract solenoid to allow signal lever to return to neutral position
setDigitalOutput(pins[SIGNAL_RELEASE_SOLENOID_INDEX], HIGH);
// setDigitalInput(pins[SIGNAL_RELEASE_SOLENOID_INDEX], PULLED);
// give some time for lever to move
delayMs(nDelay);
// release solenoid
setDigitalOutput(pins[SIGNAL_RELEASE_SOLENOID_INDEX], LOW);
// setDigitalInput(pins[SIGNAL_RELEASE_SOLENOID_INDEX], HIGH_IMPEDANCE);
Picture of hardware setup is attached.
schematic attached as pdf
Wixel_test.pdf (11.8 KB)
