Hi!
I built a line following robot but it has some problems.Could you help me please?. It has 6 pololu qtr8a analog sensors and an atmega 168 controller. It follows the line well but it wabbles and at high speeds and it loses the line. If you could help me to tune the pid a litte bit to follow the line corectly i will be very grateful. Here is the video
and the code is below. I mention that i tried to modify the pid constants but with no succes.
Thank you anticipated!
#include <PololuQTRSensors.h>
#define NUM_SENSORS 6 // number of sensors used
#define NUM_SAMPLES_PER_SENSOR 4 // average 4 analog samples per sensor reading
#define EMITTER_PIN 12 // emitter is controlled by digital pin 2
// sensors 0 through 5 are connected to analog inputs 0 through 5, respectively
PololuQTRSensorsAnalog qtra((unsigned char[]) {0, 1, 2, 3, 4, 5},
NUM_SENSORS, NUM_SAMPLES_PER_SENSOR, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
int MOTOR1_PIN1 = 5;
int MOTOR1_PIN2 = 6;
int MOTOR2_PIN1 = 11;
int MOTOR2_PIN2 = 10;
int buton = 2;
unsigned int last_proportional = 0;
long integral = 0;
void setup() {
pinMode(MOTOR1_PIN1, OUTPUT);
pinMode(MOTOR1_PIN2, OUTPUT);
pinMode(MOTOR2_PIN1, OUTPUT);
pinMode(MOTOR2_PIN2, OUTPUT);
pinMode(buton, INPUT);
delay(500);
int i;
pinMode(13, OUTPUT);
while(digitalRead(buton)==LOW)
{digitalWrite(13, HIGH);
delay(500);
digitalWrite(13,LOW);
delay(500);}
delay(2000);
digitalWrite(13, HIGH); // turn on LED to indicate we are in calibration mode
for (i = 0; i < 400; i++) // make the calibration take about 10 seconds
qtra.calibrate(); // reads all sensors 10 times at 2.5 ms per six sensors (i.e. ~25 ms per call)
digitalWrite(13, LOW); // turn off LED to indicate we are through with calibration
{digitalWrite(13,LOW);}
delay(1500);
void loop() {
unsigned int position = qtra.readLine(sensorValues);
// The "proportional" term should be 0 when we are on the line.
int proportional = ((int)position) - 2500;
// Compute the derivative (change) and integral (sum) of the
// position.
int derivative = proportional - last_proportional;
integral += proportional;
// Remember the last position.
last_proportional = proportional;
int power_difference = proportional*4 + integral/10000 + derivative*7;
// Compute the actual motor settings. We never set either motor
// to a negative value.
const int max = 255;
if(power_difference > max)
power_difference = max;
if(power_difference < -max)
power_difference = -max;
if(power_difference < 0)
go(max+power_difference, max);
else
go(max, max-power_difference);
void go(int speedLeft, int speedRight) {
if (speedLeft > 0) {
analogWrite(MOTOR1_PIN1, speedLeft);
analogWrite(MOTOR1_PIN2, 0);
else {
analogWrite(MOTOR1_PIN1, 0);
analogWrite(MOTOR1_PIN2, -speedLeft);
if (speedRight > 0) {
analogWrite(MOTOR2_PIN1, speedRight);
analogWrite(MOTOR2_PIN2, 0);
else {
analogWrite(MOTOR2_PIN1, 0);
analogWrite(MOTOR2_PIN2, -speedRight);
