hi,
I want to use TSC3200 sensor with line follower, while line follower walks, it will detect the color, but it doesnt work properly beacuse of the interrupts of the TSC3200.
How can I achieve that problem?
here is the my code
#include <TimerOne.h>
#include <QTRSensors.h>
#include <Servo.h>
#define NUM_SENSORS 8 // number of sensors used
#define TIMEOUT 2500 // waits for 2900 microseconds for sensor outputs to go low
#define EMITTER_PIN 37 // emitter is controlled by digital pin 2 //emiter iptal edildi
#define SOL_SABIT_HIZ 210
#define SAG_SABIT_HIZ 210 //85
#define M1_MAX_SPEED 210 //100
#define M2_MAX_SPEED 210
#define Motor_Sol_1 24
#define Motor_Sol_2 22
#define Motor_Sol_PWM 3
#define Motor_Sag_3 28
#define Motor_Sag_4 26
#define Motor_Sag_PWM 4
#define DEBUG 1
#define S0 37
#define S1 39
#define S2 41
#define S3 43
#define OUT 21
const int stepPin = 47;
const int dirPin = 49;
Servo servo;
Servo servo2;
int angle = 0; // servo position in degrees
int angle2 = 0;
int g_count= 0;
int g_array[3];
int g_flag=0;
float g_SF[3];
int renk[3];
QTRSensorsRC qtrrc((unsigned char[]) {34,36,38,40,42,44,46,48},
NUM_SENSORS, TIMEOUT, QTR_EMITTERS_ON);
unsigned int sensorValues[NUM_SENSORS];
void setup() {
pinMode(53,OUTPUT);
servo.attach(A4);
servo2.attach(A0);
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
pinMode(45,OUTPUT);
digitalWrite(45,HIGH);
TSC_Init();
Timer1.initialize(); // defaulte is 1s
Timer1.attachInterrupt(TSC_Callback);
attachInterrupt(2, TSC_Count, RISING);
delay(500);
for(int i=0; i<3; i++)
g_SF[0] = 255.0/ g_array[0]; //R Scale factor
g_SF[1] = 255.0/ g_array[1] ; //G Scale factor
g_SF[2] = 255.0/ g_array[2] ; //B Scale factor
delay(200);
digitalWrite(31, HIGH);
digitalWrite(33, HIGH);
digitalWrite(29, HIGH);
digitalWrite(27, HIGH);
Motor();
manual_calibration();
int hiz=190;
int baslangic_hiz=190;
int kontrol=0;
int git=6;
float bekle=0.5;
int git_m=5;
float bekle_m=0.5;
float onceki_hata=0;
int sayacyesil=0;
int sayacsari=0;
int sayackirmizi=0;
int sayacmavi=0;
int zemin=0;
void loop() {
digitalWrite(31, LOW);
digitalWrite(33, LOW);
digitalWrite(29, LOW);
digitalWrite(27, LOW);
int sol3_Min, sol2_Min, sol1_Min, sol_Min, sag_Min, sag1_Min, sag2_Min, sag3_Min;
int sol3, sol2, sol1, sol, sag, sag1, sag2, sag3, sol_Analog, orta_Analog, sag_Analog, miklatis;
int sol_MotorHiz = 0;
int sag_MotorHiz =0;
float Kp = 3;
float Kd =30; // 30
float hataOrani=0;
float turev=0;
float P=0;
float D=0;
float PID =0;
miklatis=0;
sol_Analog=0;
orta_Analog=0;
sag_Analog=0;
sol3=0;
sol2=0;
sol1=0;
sol=0;
sag=0;
sag1=0;
sag2=0;
sag3=0;
int position = qtrrc.readLine(sensorValues);
sol3=sensorValues[0];
sol2=sensorValues[1];
sol1=sensorValues[2];
sol=sensorValues[3];
sag=sensorValues[4];
sag1=sensorValues[5];
sag2=sensorValues[6];
sag3=sensorValues[7];
sol3_Min=qtrrc.calibratedMinimumOn[0];
sol2_Min=qtrrc.calibratedMinimumOn[1];
sol1_Min=qtrrc.calibratedMinimumOn[2];
sol_Min=qtrrc.calibratedMinimumOn[3];
sag_Min=qtrrc.calibratedMinimumOn[4];
sag1_Min=qtrrc.calibratedMinimumOn[5];
sag2_Min=qtrrc.calibratedMinimumOn[6];
sag3_Min=qtrrc.calibratedMinimumOn[7];
/*if(sol3>sol3_Min && sag3>sag3_Min && sol_Analog >730 && sag_Analog >730 && zemin==1)
dur();
delay(150);
zemin=0;
if(zemin==0)
hataOrani = position-3500;
if(sol3<=sol3_Min && sag3<=sag3_Min && sol_Analog <=730 && sag_Analog <=730 && zemin==0)
zemin=1;
dur();
delay(150);
zemin=1;
turev = hataOrani-onceki_hata;
P = Kp * hataOrani;
D = Kd * turev;
PID = (P + D);
sol_MotorHiz = SOL_SABIT_HIZ + PID;
sag_MotorHiz = SAG_SABIT_HIZ - PID;
onceki_hata = hataOrani;
ileri(sag_MotorHiz,sol_MotorHiz);
delay(1);
g_flag = 0;
renk[i]=(g_array[i] * g_SF[i]);
//color();
if(renk[0]-renk[1]<=20 && renk[0]-renk[1]<=20 && renk[1]-renk[0]<=20 && renk[1]-renk[2]<=20 && renk[2]-renk[1]<=20 && renk[2]-renk[0]<=20 && renk[0]<=55 && renk[1]<=55 && renk[2]<=55)
{ digitalWrite(31, LOW);
sayacyesil=0;
sayacmavi=0;
sayacsari=0;
sayackirmizi=0;
}//beyaz
else if(renk[0]-renk[1]<=20 && renk[0]-renk[1]<=20 && renk[1]-renk[0]<=20 && renk[1]-renk[2]<=20 && renk[2]-renk[1]<=20 && renk[2]-renk[0]<=20 && renk[0]>=60 && renk[1]>=60 && renk[2]>=60)
{ digitalWrite(31, HIGH);
sayacyesil=0;
sayacmavi=0;
sayacsari=0;
sayackirmizi=0;
}//siyah
else if(renk[0]>renk[1]&&renk[0]>renk[2] && ((renk[1]-renk[2])<15 && renk[0]-renk[1]>=30)){
sayacyesil=0;
sayacmavi=0;
sayacsari=0;
sayackirmizi++;
}//kırmızı
else if(renk[1]>renk[0]&&renk[1]>renk[2] && renk[0]>renk[2]){ digitalWrite(29, HIGH);
sayacyesil++;
sayacmavi=0;
sayacsari=0;
sayackirmizi=0;
}//yeşil
else if(renk[2]>renk[1]&&renk[2]>renk[0]&& renk[1]>renk[0] ){ digitalWrite(27, HIGH);
sayacyesil=0;
sayacmavi++;
sayacsari=0;
sayackirmizi=0;
}//mavi
else if(renk[0]>renk[1]&&renk[0]>renk[2] && ((renk[0]-renk[1])<30)&& renk[1]-renk[2]>=20){ digitalWrite(31, HIGH);
sayacyesil=0;
sayacmavi=0;
sayacsari++;
sayackirmizi=0;
}//sari
/*if(sayacyesil>=20){dur();geri(200,200);delay(150);dur();al();geri(100,100);delay(1000);sayacyesil=0;}
if(sayacmavi>=20){dur();geri(200,200);delay(150);dur();al();delay(300);
geri(150,150);
delay(3000);
dur();delay(1000);sola( sol3, sag3); sayacmavi=0;}
if(sayackirmizi>=20){dur();geri(200,200);delay(150);dur();al();geri(100,100);delay(1000);sayackirmizi=0;}
if(sayacsari>=20){dur();geri(200,200);delay(150);dur();al();geri(100,100);delay(1000);sayacsari=0;}
if((sol3 <= sol3_Min || sol2 <= sol2_Min ) && (sol <= sol_Min || sag <= sag_Min) && (sag2 <= sag2_Min || sag3 <= sag3_Min)) // sensorler beyazda sola don
sola( sol3, sag3);
if((sol3 <= sol3_Min) && (sol <= sol_Min || sag <= sag_Min) && (sag2 > sag2_Min || sag3 > sag3_Min)) // beyaz beyaz siyah sensor sola don
// sola( sol3, sag3);
/*if((sol3 > sol3_Min && sol2 > sol2_Min && sol1 > sol1_Min) && (sol <= sol_Min || sag <= sag_Min) && (sag1 <= sag1_Min && sag2 <= sag2_Min && sag3 <= sag3_Min)) // siyah beyaz beyaz
saga(sol3, sol2, sol1, sol, sag, sag1, sag2, sag3, sol_Analog, orta_Analog, sag_Analog,sol3_Min);
else
//diziye ileri at
digitalWrite(6, HIGH); delay(13); digitalWrite(6, LOW);
delay(2);
void color()
digitalWrite(S2, LOW);
digitalWrite(S3, LOW);
//count OUT, pRed, RED
renk[0] = pulseIn(OUT, digitalRead(OUT) == HIGH ? LOW : HIGH);
digitalWrite(S3, HIGH);
//count OUT, pBLUE, BLUE
renk[2] = pulseIn(OUT, digitalRead(OUT) == HIGH ? LOW : HIGH);
digitalWrite(S2, HIGH);
//count OUT, pGreen, GREEN
renk[1]= pulseIn(OUT, digitalRead(OUT) == HIGH ? LOW : HIGH);
void al(){
servo.write(90);
servo2.write(90);
for(angle = 90; angle >=20; angle--)
servo.write(angle);
delay(15);
delay(500);
for(angle2 = 90; angle2 >=15; angle2--)
servo2.write(angle2);
delay(15);
delay(500);
for(angle = 20; angle <180; angle++)
servo.write(angle);
delay(15);
delay(500);
for(angle2 = 15; angle2 <180; angle2++)
delay(15);
delay(500);
for(angle = 180; angle >=100; angle--)
servo.write(angle);
delay(5);
delay(500);
for(angle = 100; angle <180; angle++)
servo.write(angle);
delay(5);
delay(500);
servo.write(angle);
delay(5);
delay(500);
for(angle2 = 180; angle2 >100; angle2--)
delay(15);
delay(750);
digitalWrite(45,LOW);
digitalWrite(dirPin,LOW); // Enables the motor to move in a particular direction
// Makes 200 pulses for making one full cycle rotation
if(kontrol==2 ){
for(int x = 0; x < 33; x++) {
digitalWrite(stepPin,HIGH);
delay(20);
digitalWrite(stepPin,LOW);
delay(20);
else if(kontrol==5){
for(int x = 0; x < 35; x++) {
delay(20);
delay(20);
else{
delay(20);
delay(20);
void saga_miklatis(int sol3, int sol2, int sol1, int sol, int sag, int sag1, int sag2, int sag3, int sol_Analog, int orta_Analog, int sag_Analog){
int degisken=0;
while(1)
hiz++;
sol_Analog=analogRead(A1);
orta_Analog=analogRead(A2);
sag_Analog=analogRead(A3);
if(sol3 <= sol3_Min)
degisken=1;
if(degisken==1 && sag3 <= sag3_Min)
degisken=2;
if(degisken==2 && sag3 > sag3_Min && sol3 > sag3_Min)
degisken=0;
hiz=baslangic_hiz;
break;
if(hiz >= 90){hiz=80;}
digitalWrite(Motor_Sag_3, LOW);
digitalWrite(Motor_Sag_4, HIGH);
digitalWrite(Motor_Sol_1, HIGH);
digitalWrite(Motor_Sol_2, LOW);
analogWrite(Motor_Sag_PWM, hiz+35);
analogWrite(Motor_Sol_PWM, hiz+35);
delay(git_m);
dur();
delay(bekle_m);
void saga(int sol3, int sol2, int sol1, int sol, int sag, int sag1, int sag2, int sag3, int sol_Analog, int orta_Analog, int sag_Analog, int sol3_Min)
int degisken=0;
while(1)
hiz++;
if(sag_Analog <= 720)
degisken=1;
else if(degisken==1)
if(sag_Analog > 720)
degisken=2;
else if((degisken==2) )
if((orta_Analog <= 720))
degisken=0;
delay(100);
hiz=baslangic_hiz;
break;
analogWrite(Motor_Sag_PWM, hiz+20);
analogWrite(Motor_Sol_PWM, hiz+20);
delay(git);
dur();
delay(bekle);
/*void sola(int sol3, int sol2, int sol1, int sol, int sag, int sag1, int sag2, int sag3, int sol_Analog, int orta_Analog, int sag_Analog,int sol3_Min)
int degisken=0;
int kontrol=0;
while(1)
hiz++;
hiz++;
if(sol_Analog <= 720)
degisken=1;
if(sol_Analog > 720)
degisken=2;
degisken=0;
delay(100);
hiz=baslangic_hiz;
break;
if(sol3 > sol3_Min) kontrol=1;
else if(kontrol==1 && (sol3 <= sol3_Min)) kontrol=2;
else if(kontrol==2 && (sol3 > sol3_Min)) {kontrol=0; break;}
if(hiz >= 90){hiz=75;}
digitalWrite(Motor_Sag_3, HIGH);
digitalWrite(Motor_Sag_4, LOW);
digitalWrite(Motor_Sol_1, LOW);
digitalWrite(Motor_Sol_2, HIGH);
delay(git);
dur();
delay(bekle);
void sola(int min0, int min5){
analogWrite(Motor_Sag_PWM, hiz+60);
analogWrite(Motor_Sol_PWM, hiz+25);
while(kontrol<2)
if(sensorValues[5] > min5 && sensorValues[2] > min5 && sensorValues[3] > min5 )
if(sensorValues[2] <= min5+50 || sensorValues[3] <= min5+50 ) {kontrol=10;}
else if (sensorValues[5] > min5)
kontrol=0;
void geri(int motor1speed, int motor2speed)
if (motor1speed > M1_MAX_SPEED ) motor1speed = M1_MAX_SPEED; // limit top speed
if (motor2speed > M2_MAX_SPEED ) motor2speed = M2_MAX_SPEED; // limit top speed
if (motor1speed < 0) motor1speed = 0; // keep motor above 0
if (motor2speed < 0) motor2speed = 0; // keep motor speed above 0
analogWrite(Motor_Sag_PWM, motor1speed);
analogWrite(Motor_Sol_PWM, motor2speed);
void ileri(int motor1speed, int motor2speed)
void manual_calibration() {
int i;
for (i = 0; i <= 150; i++) //250
qtrrc.calibrate(QTR_EMITTERS_ON);
delay(20);
if (DEBUG) { // if true, generate sensor dats via serial output
Serial.begin(9600);
for (int i = 0; i < NUM_SENSORS; i++)
Serial.print(qtrrc.calibratedMinimumOn[i]);
Serial.print(' ');
Serial.println();
Serial.print(qtrrc.calibratedMaximumOn[i]);
Serial.print(' ');
Serial.println();
Serial.println();
void Motor(){
pinMode(Motor_Sol_1, OUTPUT);
pinMode(Motor_Sol_2, OUTPUT);
pinMode(Motor_Sag_PWM, OUTPUT);
pinMode(Motor_Sag_3, OUTPUT);
pinMode(Motor_Sag_4, OUTPUT);
pinMode(Motor_Sol_PWM, OUTPUT);
pinMode(3, OUTPUT);
pinMode(2, OUTPUT);
digitalWrite(50, HIGH);
void dur(){
analogWrite(Motor_Sag_PWM, 255);
analogWrite(Motor_Sol_PWM, 255);
delay(3000);
// Init TSC230 and setting Frequency.
void TSC_Init()
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(OUT, INPUT);
pinMode(33, OUTPUT);
pinMode(31, OUTPUT);
pinMode(29, OUTPUT);
pinMode(27, OUTPUT);
digitalWrite(S0, HIGH); // OUTPUT FREQUENCY SCALING 2%
digitalWrite(S1, HIGH);
// Select the filter color
void TSC_FilterColor(int Level01, int Level02)
if(Level01 != 0)
Level01 = HIGH;
if(Level02 != 0)
Level02 = HIGH;
digitalWrite(S2, Level01);
digitalWrite(S3, Level02);
void TSC_Count()
g_count ++ ;
void TSC_Callback()
switch(g_flag)
case 0:
TSC_WB(LOW, LOW); //Filter without Red
break;
case 1:
g_array[0] = g_count;
TSC_WB(HIGH, HIGH); //Filter without Green
break;
case 2:
g_array[1] = g_count;
TSC_WB(LOW, HIGH); //Filter without Blue
break;
case 3:
g_array[2] = g_count;
TSC_WB(HIGH, LOW); //Clear(no filter)
break;
default:
g_count = 0;
break;
void TSC_WB(int Level0, int Level1) //White Balance
g_count = 0;
g_flag ++;
TSC_FilterColor(Level0, Level1);
Timer1.setPeriod(250); // set 1s period
