Hi all. I’m trying to make a “meltybrain” translational drift robot. I was hoping to use the “OpenMelt” code that someone had made and posted some years ago (Open Melt - Open Source Melty Brain / Translational Drift). Open Melt calls for a Baby Orangutan B-328, which I have, and I’m trying to get the program onto the 328 with a USB AVR 2.1 programmer.
I’m getting an error when I try to compile the OpenMelt code. The error is “can’t open device Com1” (grab attached). I can see com1 called out in the Makefile (second grab). I’ve just started to play around the with 328 and I’m new to programming. But, I’ pretty sure I need to spec the programming port in the Make file to get the compiling to complete. I believe the OpenMelt code was made quite some years ago and I assume it was made for a Windows PC. I’m running a Mac.
So my question is, does anyone know what/where I need to update in the Make File to address this com1 error? Is it a matter of replacing the call out to com1 with my programming port (/dev/cu.usbmodem00282452)? Or some other fix? Thanks for any ideas!
