I’m working on an I2C addon for Node.js (on raspberry pi), and I’m having trouble writing to a register.
I’m using the mini-imu 9v2 as a test device.
I can read values without problem, and writing seems to work ok, it’s just that the value doesn’t change.
I’m probably doing something wrong in my i2c code in c++, but I just can’t see what it is.
I’m attempting to enable the device by writing 0xF to the register at 0x20.
Any help would be greatly appreciated
Here’s the output of my code:
Created i2c object
Set Device: 0:6B
Read from 0x20: 7
Write to 0x20: F
Read from 0x20 7
Here’s the c++ code to actually perform the read/writes:
[code]/**
- Set the i2c device to be accessed
- @param int i2c bus number
- @param int i2c device address
@return String device address or error message
Handle SetDevice(const Arguments& args) {
HandleScope scope;
busNum = args[0]->Int32Value();
v8::Local busTitle = args[0]->ToString();
deviceAddress = args[1]->Int32Value();
char deviceTitle[1];
sprintf(deviceTitle, “%X”, deviceAddress);
v8::Local addressTitle = String::Concat(String::Concat(busTitle, String::New(":")), String::New(deviceTitle));
if (busNum != 0 && busNum != 1) { // TODO: better validation
return scope.Close(String::New(“Unknown I2C Bus”));
// Open i2c bus
if(( i2c_bus = open( “/dev/i2c-0”, O_RDWR )) < 0 ) // TODO: fix hardcoded device address
return scope.Close(String::New(“Unable to open file /dev/i2c-0.\n”));
// Set the device address
if( ioctl( i2c_bus, I2C_SLAVE, deviceAddress ) < 0 )
return scope.Close(String::New(“Open Device FAILED”));
return scope.Close(String::Concat(String::New("Set Device: "), addressTitle));
- Read a value from a regiser
- @param int register address
- @param int num bytes to read
@return String the value of the register, or error message
Handle Read(const Arguments& args) {
HandleScope scope;
char buf[32];
buf[0] = args[0]->Int32Value();
int readSize = args[1]->Int32Value();
// Set the device register to read from
if ((write(i2c_bus, buf, 1)) != 1) {
return scope.Close(String::New(“Set register to read from failed”));
// Read from the device register into the buffer
if (read(i2c_bus, buf, readSize) != readSize) {
return scope.Close(String::New(“Reading after write to register failed”));
// Return the result as a string
char result[3];
sprintf(result, “%X”,buf[0]);
return scope.Close(String::New(result));
- Write a value to a register
- @param int value to write
@return String the value written to the register or error message
Handle Write(const Arguments& args) {
HandleScope scope;
char buf[1];
int writeSize = 1; // TODO: fix hardcoded value size
// Set the device register to write to
return scope.Close(String::New(“Set register to write to failed”));
buf[0] = args[1]->Int32Value();
// Write to the device register
if (write(i2c_bus, buf, writeSize) != writeSize) {
return scope.Close(String::New(“Write to register failed”));
char writeVal[1];
sprintf(writeVal, “%X”, buf[0]);
return scope.Close(String::New(writeVal));
}[/code]
