Are there any VL53L1X size equivalent ToF sensors that would have bigger Field of View than 27 degrees and able to measure up to at least a metre.
I also found VL6180X, but it ranges only to about 10 cm.
Hope for the best!
Hope for the best!
Hi, sensor53.
Unfortunately, we do not have any ToF sensors other than those two and the VL53L0X (which has a similar FoV). You might consider other types of distance sensors if that is an option for you; in particular, the Maxbotix sonar range finders are available in a range of beam angles that are well characterized.
Kevin
