Hi there!
First of all let me thank you. Great code!
Could you explain how to use lsm303-arduino library with teensy 3.6 properly?
I ran “Serial” example and got these outputs:
A: -1 -1 -1 M: -1 -1 -1
Could you post some pictures of your setup that show all of your connections?
BrandonM thy for a rapid response.
My setup is:
Compass C_pin - connected with - 19_pin teensy
Compass D_pin - connected with - 18_pin teensy
Compass V_pin - connected with - 3.3V_pin teensy
Compass G_pin - connected with - GND_pin teensy
Thank you for the connection descriptions, but pictures showing your connections would still be most helpful. Also, those pin names do not match the pin names on our LSM303D carrier; are you using one of our boards?
