I’m interested in removing the configuration jumper #2 on item #4064 to change the max range from 50cm down to 15cm, but I’ve never worked on anything that small. My goto tool is a pencil soldering iron with a 1/32” semi-chisel tip.
So I was wondering if someone could suggest a technique for removing the 0 ohm resistor at position #2? One idea I had was to take a pair of fine tipped tweezers, warm them for a a few seconds with a heat gun, then pinch the soldered ends of the resistor to remove… Do you think that would work?
Thanks Tom
