Hi, I have a question about tb6612fng output current. In the description,it states that 3.2 A is the peak out current. So if I had 2 DC Motors, 2 A per motor, would the motor driver work just fine?
Thank you
It is not clear to me what your 2A figure is (i.e. your motor’s stall current, the continuous current it will draw in your application, or some other rating). However, for choosing an appropriate motor driver, we generally recommend a motor driver that can handle the stall current of your motor continuously.
The TB6612FNG can handle around 1A continuously without additional cooling.
If that does not answer your question, could you post more information about your motor (such as a link to it’s product page or a spec sheet)?
