Can you tell me the switching frequency of the 6V Step-Up Voltage Regulator U3V50F6? I want to use it in a sensor application and need to know a little bit more about noise the power supply may generate. Thank you!
Hi.
The switching frequency of our U3V50F6 Stup-up/Step-down Voltage Regulator is around 550kHz. However, it has a power saving more that reduces the switching frequency during light loads to increase efficiency.
-Claire
