Good day to everybody
I apologise in advance if this or similar post has been already answered but I wasnât able to find it. Also, I am a complete beginner and even I tried to read and understand some blogs I think still many things are not clear.
I would like to ask any experienced person about a recommendation. I would like to build a robot with a normal digital camera (Ricoh 250grams) on the top using .Net Gadgeteer (I am c# developer) which moves very slowly and smoothly, I will say how slow in a moment
âŚThis robot is not going on Mars ha ha
I am looking for all parts I would need and found âDagu Wild Thumper 4WD All-Terrain Chassisâ which I really love as I could use it also out door
Just to get lesson on this, if the wheels are 120mm in diameter (circumference=37.6cm?) and 75:1 steel gearboxes on the motors is used:
what would be the theoretical maximum and minimum speed? Please, could the calculation be provided so I could learn/understand?
1a) well the website says max speed is 3km/hour how did they calculated this speed? -
If I would like to move my robot with a speed
a) 10meters/hour
b) 10-20meters/hour
c) 5-10meters/hour
How could I achieve this task? If I am calculating right in case of a) I would need some motor with a speed of: 10 meters = 1000 cm / 37.6cm = 26.59 / 60 minutes = 0.44rpm? (2.77mm/second) -
Does Pololu sell such a slow motors which would be compatible with âDagu Wild Thumper 4WD All-Terrain Chassisâ or do I need a gear box to achieve this?
I am just guessing, if I used .Net Gadgeteer I could also program that motor switches on/off every few seconds so I could move the robot super slowly but wouldnât be movement jerky?
Can the batteries last 1-3 hours moving this robot?
To go to the next level
Can I get any nice Pan and Tilt platform/tower from Pololu I could use on the top of the chassis for my camera? I would like again slow motion movement maybe 360degrees/hour. Can you recommend such a platform or motors?
Really, really, thank you very much for your time on this, I might have more question later but these are kind of foundation I would like to understand.
Regards, Vaclav Elias.
