I work on a robot that avoid obstacles and uses Orangutan X2.
I would like to save two of my float variables (the position x and y) into the memory of the micro-controller every seconds and be able afterward to read these values in order to make a graph on Excel. Should I use the EEPROM ? How can I write my values ? Is it possible to read them directly using AVR Studio ?
If you need more precision i’ll be glad to give them to you.
Thank you for your help
I wrote my data to RAM and then dumped the contents to the serial USB connection which I then captured using putty (terminal program). I took the output from putty and pasted it into an Excel spreadsheet.
When it was time to dump the contents, I printed a message on the LCD to prompt me to connect the USB and then waited for a button press before sending to the USB serial.
// val1[] and val2[] hold up to max_log_items values
clear();
print("Mid Button Dump");
wait_for_button_press(MIDDLE_BUTTON);
clear();
print("Dumping...");
char send_buffer[200];
int idx;
for (idx = 0; idx < max_log_items; idx++)
sprintf(send_buffer, "val1:%d val2:%d\r\n", val1[idx], val2[idx]);
serial_send_blocking(USB_COMM, send_buffer, strlen(send_buffer));
clear();
print("Dump Done");
delay_ms(2000);
Thank you Mike. This is exactly what i was looking for.
I would like to know where I can find the serial_send_blocking() function. Is it in some .h file ? What is the USB_COMM value on a Orangutan X2?
Not sure which Orangutan X2 you are using but if you click on the resource tab you will find a great deal of information. For example here is the information supplied for the Orangutan X2 with VNH3: pololu.com/catalog/product/716/resources
Thanks a lot for all these information.
I tried to implement it but run into a lot of conflict since I already use the timers in my project and these same timers are defined somewhere else in the Pololu lib. Since it is a .a file it is not easy to modify it.
That a shame since your solution would have work perfectly
