hi,
i have a 8825 stepper driver and i wonder what is the most efficient way to get away the heat?
i am new at this topic so i need recommendations which sort of thermal adhesive ist the best. it should also have a high fixing power. can you recommend one?
is it better to glue it on the side of the ic or on the exposed solderable ground pad on the bottom of the PCB? or even both sides?
i have a 20x5x2 cm aluminium socket buildt in my machine. which normally should be at room temperature or maybe 5 deg. C above. is it a good idea to directly solder it together with the solderable ground pad??
