Step-Down Regulator Temp Specs
I have a couple step down regulator families I’m looking at (D45V5Fx, D36V50Fx, and D30V30Fx to name a couple). Where can I find the temp specs for the different regulators? I need them to be able to handle between 0C and +80C.
We have not thoroughly characterized the operating temperature ranges for those regulators; our characterization tests are done at ambient room temperatures. However, based on the components currently used, I generally expect them to be fine between the temperatures listed below, although you should expect to see some derated performance as you near those extremes.
Regulator Family Minimum temp Maximum temp
D45V5Fx -40°C 125°C
D36V50Fx -40°C 85°C
D30V30Fx -55°C 85°C
Please let me know if you have any additional questions or concerns.
