Im trying to controll a hexapod robot with a mini maestro 24 via serial commands from an arduino
I compile a script with a simple routine to walk forwards and try to call the sub routines from the arduino via the commands:
MaestroSerial.print(0xA7, BYTE); // command to call up subroutine
MaestroSerial.print(0x00, BYTE); // subroutine number
and i keep getting an error code of 0x0040 wich is stack over/under flow
here is my script:
[code] # WalkForwards
begin
200 6112 5840 5840 8112 7840 5840
6112 5840 5840 4112 3840 5840
6112 5840 5840 6112 3840 0
7840 0 0 0 0 0 frame_0…23 # First Step
200 5840 5840 5840 frame_4_10_16 # transitionFromFirst
200 7840 3840 6112 8112 7840 6112
4110 3840 5840 frame_1…3_6_7_9_12_13_18 # Second Step
200 5840 5840 5840 frame_1_7_13 # TransitionFromSecond
repeat
sub frame_0..23
23 servo
22 servo
21 servo
20 servo
19 servo
18 servo
17 servo
16 servo
15 servo
14 servo
13 servo
12 servo
11 servo
10 servo
9 servo
8 servo
7 servo
6 servo
5 servo
4 servo
3 servo
2 servo
1 servo
0 servo
delay
return
sub frame_4_10_16
16 servo
10 servo
4 servo
delay
return[/code]
now i know i have to replace the returns with a quit command but when i attempt this i get the same error code
Im confused on how to properly do this
–Richard
