Hello!
I’m working on a project that incorporates a number of servo motors. Their operating range are either 4.8-6V or 6-7.4V.
I want to know of this regulator will be able to provide a stable 6V and 7.4V output (using two of them, depending on the motor).
I’m using a 22.2V (6S LiPo) battery.
I saw that your S18V20F6 had a deviation of up to 4%, so I am wondering if this one will bring the voltage closer to my desired voltages.
I need a very stable output voltage because I need to know the time it takes for the motors to rotate say 60 degrees.
Sorry for the messy post, so to sum it up: how stable is this voltage regulator when you set the output to 6V and 7.4V respectively?
Thank you - dreh
