Hello, will the SPDT Relay Carrier be able to drive a 24V relay? I’m not an electronics expert but the data sheet for the BSS138 says it is good for up to 50 volts. There is a 24V Omron relay that will drop into the board.
Hi.
It should be fine to use our Basic SPDT Relay Carrier with a 24V relay since D3 is also rated for at least 50V. The LEDs will be extra bright though.
-Claire
