Source Code for the Maestro and Listens to Commands Once and Breaks for Good
This is the file for compilation to get
./maestro to be called once compiled. Once compiled, the file maestro tells me to Enter Position:
#include <iostream>
#include <libusb-1.0/libusb.h>
#include "protocol.h"
using namespace std;
bool deviceMatchesVendorProduct(libusb_device *device, unsigned short idVendor, unsigned short idProduct)
    libusb_device_descriptor desc;
    libusb_get_device_descriptor(device, &desc);
    return idVendor == desc.idVendor && idProduct == desc.idProduct;
void setTarget(int position, int servo)
    const unsigned short vendorId = 0x1ffb;
    unsigned short productIDArray[]={0x0089, 0x008a, 0x008b, 0x008c};
    libusb_context *ctx=0;
    libusb_device **device_list=0;
    libusb_init(&ctx);
    int count=libusb_get_device_list(ctx, &device_list);
    for(int i=0;i<count;i++)
        libusb_device *device=device_list[i];
            for(int Id=0;Id<4;Id++)
                if(deviceMatchesVendorProduct(device, vendorId, productIDArray[Id]))
                    libusb_device_handle *device_handle;
                    libusb_open(device, &device_handle);
                    libusb_control_transfer(device_handle, 0x40, REQUEST_SET_TARGET, position*4, servo, 0, 0, (ushort)5000);
                    libusb_close(device_handle);
                    break;
    libusb_free_device_list(device_list, 0);
    libusb_exit(ctx);
int main()
    while(1)
        int position;
        int servo=0;
        cout << "Enter position: ";
        cin >> position;
        setTarget(position, servo);
    return 0;
This is the constants file for compilation, e.g. protocol.h
/* This C header file that defines the constants needed to communicate with the
   Maestro via USB, USB serial, or TTL serial.
   Most of the information here is also in Usc_protocol.cs.
   This file can be included directly in C/C++ programs or used
   as a reference when writing programs in other languages.
// Serial commands, sent on the virtual serial port or over TTL Serial.
// See the user's guide at http://www.pololu.com/docs/0J40 for more info.
enum uscCommand
    COMMAND_SET_TARGET = 0x84, // 3 data bytes
    COMMAND_SET_SPEED = 0x87, // 3 data bytes
    COMMAND_SET_ACCELERATION = 0x89, // 3 data bytes
    COMMAND_GET_POSITION = 0x90, // 0 data
    COMMAND_GET_MOVING_STATE = 0x93, // 0 data
    COMMAND_GET_ERRORS = 0xA1, // 0 data
    COMMAND_GO_HOME = 0xA2, // 0 data
    COMMAND_STOP_SCRIPT = 0xA4, // 0 data
    COMMAND_RESTART_SCRIPT_AT_SUBROUTINE                = 0xA7, // 1 data bytes
    COMMAND_RESTART_SCRIPT_AT_SUBROUTINE_WITH_PARAMETER = 0xA8, // 3 data bytes
    COMMAND_GET_SCRIPT_STATUS = 0xAE, // 0 data
    COMMAND_MINI_SSC = 0xFF, // (2 data bytes)
// These are the values to put in to bRequest when making a setup packet
// for a control transfer to the Maestro.  See the comments and code in Usc.cs
// for more information about what these requests do and the format of the
// setup packet.
enum uscRequest
    REQUEST_GET_PARAMETER = 0x81,
    REQUEST_SET_PARAMETER = 0x82,
    REQUEST_GET_VARIABLES = 0x83,
    REQUEST_SET_SERVO_VARIABLE = 0x84, // (also clears the serial timeout timer)
    REQUEST_SET_TARGET = 0x85,   // (also clears the serial timeout timer)
    REQUEST_CLEAR_ERRORS = 0x86, // (also clears the serial timeout timer)
    REQUEST_REINITIALIZE = 0x90,
    REQUEST_ERASE_SCRIPT = 0xA0,
    REQUEST_WRITE_SCRIPT = 0xA1,
    REQUEST_SET_SCRIPT_DONE = 0xA2, // value.low.b is 0 for go, 1 for stop, 2 for single-step
    REQUEST_RESTART_SCRIPT_AT_SUBROUTINE = 0xA3,
    REQUEST_RESTART_SCRIPT_AT_SUBROUTINE_WITH_PARAMETER = 0xA4,
    REQUEST_RESTART_SCRIPT = 0xA5,
    REQUEST_START_BOOTLOADER = 0xFF
// These are the bytes used to refer to the different parameters
// in REQUEST_GET_PARAMETER and REQUEST_SET_PARAMETER.  After changing
// any parameter marked as an "Init parameter", you must do REQUEST_REINITIALIZE
// before the new value will be used.
enum uscParameter
    PARAMETER_SERVOS_AVAILABLE                  = 1, // 1 byte - 0-5.  Init parameter.
    PARAMETER_SERVO_PERIOD                      = 2, // 1 byte - instruction cycles allocated to each servo/256, (units of 21.3333 us).  Init parameter.
    PARAMETER_SERIAL_MODE                       = 3, // 1 byte unsigned value.  Valid values are SERIAL_MODE_*.  Init parameter.
    PARAMETER_SERIAL_FIXED_BAUD_RATE            = 4, // 2-byte unsigned value; 0 means autodetect.  Init parameter.
    PARAMETER_SERIAL_TIMEOUT                    = 6, // 2-byte unsigned value (units of 10ms)
    PARAMETER_SERIAL_ENABLE_CRC                 = 8, // 1 byte boolean value
    PARAMETER_SERIAL_NEVER_SUSPEND              = 9, // 1 byte boolean value
    PARAMETER_SERIAL_DEVICE_NUMBER              = 10, // 1 byte unsigned value, 0-127
    PARAMETER_SERIAL_BAUD_DETECT_TYPE           = 11, // 1 byte - reserved
    PARAMETER_IO_MASK_A                         = 12, // 1 byte - reserved, init parameter
    PARAMETER_OUTPUT_MASK_A                     = 13, // 1 byte - reserved, init parameter
    PARAMETER_IO_MASK_B                         = 14, // 1 byte - reserved, init parameter
    PARAMETER_OUTPUT_MASK_B                     = 15, // 1 byte - reserved, init parameter
    PARAMETER_IO_MASK_C                         = 16, // 1 byte - pins used for I/O instead of servo, init parameter
    PARAMETER_OUTPUT_MASK_C                     = 17, // 1 byte - outputs that are enabled, init parameter
    PARAMETER_IO_MASK_D                         = 18, // 1 byte - reserved, init parameter
    PARAMETER_OUTPUT_MASK_D                     = 19, // 1 byte - reserved, init parameter
    PARAMETER_IO_MASK_E                         = 20, // 1 byte - reserved, init parameter
    PARAMETER_OUTPUT_MASK_E                     = 21, // 1 byte - reserved, init parameter
    PARAMETER_SCRIPT_CRC                        = 22, // 2 byte CRC of script
    PARAMETER_SCRIPT_DONE                       = 24, // 1 byte - if 0, run the bytecode on restart, if 1, stop
    PARAMETER_SERIAL_MINI_SSC_OFFSET            = 25, // 1 byte (0-254)
    PARAMETER_SERVO0_HOME                       = 30, // 2 byte home position (0=off; 1=ignore)
    PARAMETER_SERVO0_MIN                        = 32, // 1 byte min allowed value (x2^6)
    PARAMETER_SERVO0_MAX                        = 33, // 1 byte max allowed value (x2^6)
    PARAMETER_SERVO0_NEUTRAL                    = 34, // 2 byte neutral position
    PARAMETER_SERVO0_RANGE                      = 36, // 1 byte range
    PARAMETER_SERVO0_SPEED                      = 37, // 1 byte (5 mantissa,3 exponent) us per 10ms.  Init parameter.
    PARAMETER_SERVO0_ACCELERATION               = 38, // 1 byte (speed changes that much every 10ms). Init parameter.
    PARAMETER_SERVO1_HOME                       = 39,
    // The pattern continues.  Each servo takes 9 bytes of configuration space.
struct servoSetting
    int position;
    int target;
    unsigned int speed;
    unsigned int acceleration;
/* uscVariables: This struct stores all the variables that can be read via
   REQUEST_GET_VARIABLES.
   There are 12 bytes used per servo setting
struct uscVariables
    // Fix bytecode_asm.asm if you change the order or size of
    // variables in this struct.
    // offset: 0
    unsigned int stackPointer;
    // offset: 1
    unsigned int callStackPointer;
    // offset: 2
     unsigned int errors;
    // offset: 4
     unsigned int programCounter;
    // offset: 6
    int buffer[3]; // protects other RAM from being corrupted by improper instructions
    // offset: 12
    int stack[32];
    // offset: 76
unsigned int callStack[10];
    // offset: 96
    unsigned int scriptDone; // 1 = done; 2 = about to run a single step then be done - placed here to protect against accidental overwriting of Setting
    // offset: 97
    unsigned int buffer2; // protects other RAM from being corrupted by improper instructions
    // offset: 98
    struct servoSetting servoSetting[6];
}; // total length 139 bytes
#define BAUD_DETECT_TYPE_AA 0u
#define BAUD_DETECT_TYPE_FF 1u
// serialMode: Value of PARAMETER_SERIAL_MODE.
enum serialMode
    // On the Command Port, user can send commands and receive responses.
    // TTL port/UART are connected to make a USB-to-serial adapter.
    SERIAL_MODE_USB_DUAL_PORT = 0u,
    // On the Command Port, user can send commands to UMC01 and
    // simultaneously transmit bytes on the UART TX line, and user
    // can receive bytes from the UMC01 and the UART RX line.
    // COM2 does not do anything.
    SERIAL_MODE_USB_CHAINED = 1u,
    // On the UART, user can send commands and receive reponses.
    // Command Port and TTL Port don't do anything.
    SERIAL_MODE_UART_DETECT_BAUD_RATE = 2u,
    SERIAL_MODE_UART_FIXED_BAUD_RATE = 3u,
// There are several different errors.  Each error is represented by a
// different bit number from 0 to 15.
#define ERROR_SERIAL_SIGNAL            0
#define ERROR_SERIAL_OVERRUN           1
#define ERROR_SERIAL_BUFFER_FULL       2
#define ERROR_SERIAL_CRC               3
#define ERROR_SERIAL_PROTOCOL          4
#define ERROR_SERIAL_TIMEOUT           5
#define ERROR_SCRIPT_STACK             6
#define ERROR_SCRIPT_CALL_STACK        7
#define ERROR_SCRIPT_PROGRAM_COUNTER   8
// Local Variables: **
// mode: C **
// c-basic-offset: 4 **
// tab-width: 4 **
// indent-tabs-mode: t **
// end: **
Why does it work once and not any longer after the initial command?
I got some other source from the forums and from the website to work but I am trying to get the while loop in this source code to listen at intervals when it is telling me to Enter Position:
Seth
P.S. I will be reading up and trying to learn. In the meantime and if you know, please direct me on why this source code created a one-time-only output to the input.
update
It takes negative integers!
Sorry for harassing you guys/gals again…
