I’m currently using mini maestro 6 to control servos and they work great.
Is there a way I can use a sound sensor to start a script that will let the servos move to a routine?
Thanks
Jon
Thanks
Jon
You could probably do something like that, but it would require some scripting. The details about how to do something like that depends heavily on the sound sensor (and if it outputs a signal that would be practical to use with the Maestro); did you have any particular sound sensor in mind?
For example, this hand clap sensor we carry has a simple digital interface that can be used with one of the Maestro channels that is configured as an input to detect when a clap or snap happens. So, you could write a script that waits for that to happen and goes into your routine when it does.
