[SOLVED] Mini Maestro - Using C# and setTarget()
I am attempting to set up a small demo program in C# to move a servo 0 on a 24-channel Mini Maestro servo controller. However, when I try to compile in Visual Studio 2013, I receive the following errors:
I assume that I must add additional C# Pololu class files to the project, but which ones? I can compile the C# demo programs in the USB SDK, but am unclear on how to set up a new project from scratch. I have been referring to the following forum thread: https://forum.pololu.com/t/micro-maestro-info-for-sentry-gun-makers/1673/1
I am new to C#, so perhaps I have overlooked something obvious. My code is below:
//A simple test program to set servo position on the Pololu Mini Maestro using C#
//This program was created from a blank VisualStudio console program template.
//See: https://forum.pololu.com/t/micro-maestro-info-for-sentry-gun-makers/1673/1
//Note: Must add the following files to the Solution Explorer:
//      Usc.cs, Usc_protocol.cs, UscSettings.cs, IUscSettingsHolder.cs, ConfigurationFile.cs
//Note: To remove error message "Unsafe code may only appear if compiling with /unsafe," go to:
//      Solution Explorer> Properties > Build > [tick box]: Allow unsafe code
//      See: http://stackoverflow.com/questions/2026410/why-do-i-get-the-error-unsafe-code-may-only-appear-if-compiling-with-unsafe
//default using statements from VisualStudio template
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
//added using statements
using System.Reflection;    //Used by the Pololu UscCmd demo program.  Not sure if this is required here.
using Pololu.UsbWrapper;    //The Bytecode and UsbWrapper DLLs from the Pololu SDK folder must be manually added to the references section of the Solution Explorer, see: https://msdn.microsoft.com/en-us/library/6taasyc6(v=vs.80).aspx
using Pololu.Usc.Bytecode;
namespace MaestroServoTest
    class Program
        static void Main(string[] args)
            int servoNumber = 0;
            int servoTarget = (1500 * 4); //specify in units of quarter-milliseconds
            usc.setTarget(servoNumber, servoTarget);
It looks like you already figured out how to add a reference to Bytecode. You just need to do the same thing for Sequencer. We provide it both as a C# project and a DLL in the Maestro folder of the Pololu USB SDK.
Thanks David!
Using that bit of info and adapting some code from the UscCmd program, I was finally able to get my program to run.
I have included my complete code listing below in the hopes that other beginners will find it useful. Cheers!
EDIT - units of setTarget() are quarter microsecond (10^-6 s), not quarter millisecond (10^-3 s) as first posted.
//This program was created from a blank Visual Studio Express 2013 console program template.
//NOTE: Must add the following files from the Pololu USB SDK to the Solution Explorer:
//NOTE: To remove error message "Unsafe code may only appear if compiling with /unsafe," go to:
//NOTE: The Bytecode, Sequencer, and UsbWrapper DLLs from the Pololu USB SDK folder must be manually added to the "References"
//      section of the Solution Explorer, see: https://msdn.microsoft.com/en-us/library/6taasyc6(v=vs.80).aspx
//      The respective file paths are:
//          pololu-usb-sdk\Maestro\Bytecode
//          pololu-usb-sdk\Maestro\Sequencer\precompiled_obj
//          pololu-usb-sdk\UsbWrapper_Windows
//default using statements from Visual Studio template:
using System;
using System.Linq;
using System.Text;
//additional using statements:
//using System.Reflection;    //Used by the Pololu UscCmd demo program.  Does not seem to be required here.
//using Pololu.Usc.Sequencer;  //Does not seem to be required here
using Pololu.Usc;
    class Program
            //this section adapted from Pololu UscCmd program
            List<DeviceListItem> list = Usc.getConnectedDevices();
            if (list.Count == 0)
                Console.WriteLine("No " + Usc.englishName + " devices found.");
                Console.WriteLine("Press ENTER to exit.");
                Console.ReadLine();  //causes console window to stay open for user to read output
                return;
            DeviceListItem item = null;
            item = list[0];
            Usc usc = new Usc(item);
            //endsection
            byte servoNumber = 0;             //connect a servo to channel specified here
            ushort servoTarget = (2000 * 4);  //enter desired servo pusle width here.  Multiplying by 4 converts to the required
                                              //    units of quarter-microsecond.
            //print data to console for debugging purposes
            Console.WriteLine("servoNumber is " + servoNumber);
            Console.WriteLine("servoTarget is " + servoTarget + " (" + (servoTarget/4) + " ms)");
