The Texas Instruments Speak & Spell from the 1970’s lives on! This was a pretty remarkable toy that generated quite passable speech, based on an extremely primitive 4-bit microprocessor.
Peter Knight wrote an AVR emulator for the Linear Predictive Coding algorithm used in the Speak & Spell and together with binary dumps of several different ROMs that used the TI speech processor, one can cobble together a pretty cool package for purely software-generated speech.
See elek101.blogspot.com/2012/12/ard … clock.html for a talking clock based on the code. That link gives an audio example of the speech quality and has a link pointing to Peter’s GitHub deposition, which includes a great deal of interesting stuff, including experimental MATLAB code to roll your own speech libraries.
I would NOT recommend connecting a speaker to an output pin as the above clock example shows. I used a small audio amp instead.
I modified Peter’s Talkie code to run on the 20 MHz Orangutan LV-168 (after removing the C++ constructs and changing the output of timer2 to PB3). I also had to change one of the delay timing constants in the routine Say() to get the voice cadence to be reasonable. Below is the main routine for a talking demo, but you can download a self-contained package with all the mods at molbio.uoregon.edu/~remington/talkie.zip
This was developed using AVR Studio 4, so there may be issues with later versions of the IDE. Let me know if so! Note: my example takes up about 7K bytes of flash, so it is memory intensive.
// Talkie library
// Copyright 2011 Peter Knight
// mods for LV-168 Orangutan by Jim Remington 9/2013
// changes made: output on PB3, delay timing change in Say()
// This code is released under GPLv2 license.
// https://github.com/going-digital/Talkie
// Welcome to the Talkie library examples. //
// Talkie is a speech synthesiser that works from a fixed vocabulary.
// There are hundreds of words in the 'Vocabulary' examples.
// Sound is output on PB3. It can drive headphones directly, or add a simple audio amplifier to drive a loudspeaker.
#include "talkie.h"
#include <stdio.h>
#include <inttypes.h>
#define F_CPU 20000000UL
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <avr/pgmspace.h>
//male voice examples
uint8_t spDANGER[] PROGMEM = {0x2D, 0xBF, 0x21, 0x92, 0x59, 0xB4, 0x9F, 0xA2, 0x87, 0x10, 0x8E, 0xDC, 0x72, 0xAB, 0x5B, 0x9D, 0x62, 0xA6, 0x42, 0x9E, 0x9C, 0xB8, 0xB3, 0x95, 0x0D, 0xAF, 0x14, 0x15, 0xA5, 0x47, 0xDE, 0x1D, 0x7A, 0x78, 0x3A, 0x49, 0x65, 0x55, 0xD0, 0x5E, 0xAE, 0x3A, 0xB5, 0x53, 0x93, 0x88, 0x65, 0xE2, 0x00, 0xEC, 0x9A, 0xEA, 0x80, 0x65, 0x82, 0xC7, 0xD8, 0x63, 0x0A, 0x9A, 0x65, 0x5D, 0x53, 0xC9, 0x49, 0x5C, 0xE1, 0x7D, 0x2F, 0x73, 0x2F, 0x47, 0x59, 0xC2, 0xDE, 0x9A, 0x27, 0x5F, 0xF1, 0x8B, 0xDF, 0xFF, 0x03};
uint8_t spMOTOR[] PROGMEM = {0x66, 0xAA, 0x8C, 0x69, 0x53, 0x92, 0xC4, 0x2D, 0x2F, 0x6B, 0x2A, 0x74, 0xDA, 0x9D, 0xB2, 0xDD, 0xF6, 0x36, 0xAB, 0xCE, 0x78, 0xDA, 0x9D, 0xB2, 0xD5, 0x9A, 0x01, 0xDB, 0x77, 0x45, 0xA0, 0x75, 0xC5, 0xB8, 0x71, 0x59, 0xDA, 0x31, 0xE5, 0x6A, 0x22, 0x63, 0xDE, 0xDA, 0x9A, 0xBB, 0xA3, 0x75, 0x68, 0xAF, 0x7B, 0x3E, 0xC3, 0x9D, 0x97, 0x60, 0x87, 0xE6, 0x8B, 0x4F, 0x78, 0x4B, 0x76, 0xB2, 0x09, 0xAF, 0xFE, 0xFD, 0x7F};
uint8_t spFIRE[] PROGMEM = {0x04, 0x18, 0xCE, 0x4D, 0x02, 0x1A, 0xD0, 0x80, 0x04, 0x46, 0x91, 0x55, 0x57, 0x07, 0x6D, 0xD9, 0xCD, 0xAE, 0x4F, 0x55, 0x5D, 0x59, 0x87, 0xAE, 0xB9, 0xD5, 0x6D, 0x5B, 0xDB, 0x7D, 0x93, 0xB6, 0xED, 0xEE, 0xE3, 0x5A, 0x6B, 0x6A, 0xF4, 0x91, 0xD5, 0x73, 0x6B, 0x67, 0xF5, 0x47, 0xBC, 0xD4, 0xA7, 0x9C, 0xA5, 0x34, 0xE4, 0xD0, 0xA6, 0xF0, 0xE4, 0xAA, 0xB8, 0x2D, 0xAB, 0xC3, 0x9B, 0x62, 0xC2, 0xAC, 0x74, 0xF6, 0x9F, 0xFB, 0x72, 0x0B, 0xEC, 0x92, 0xCD, 0xEE, 0xCF, 0x43, 0x69, 0x4C, 0x5B, 0xFF, 0x3F};
uint8_t spON[] PROGMEM = {0x65, 0x4A, 0xEA, 0x3A, 0x5C, 0xB2, 0xCE, 0x6E, 0x57, 0xA7, 0x48, 0xE6, 0xD2, 0x5D, 0xBB, 0xEC, 0x62, 0x17, 0xBB, 0xDE, 0x7D, 0x9F, 0xDA, 0x5C, 0x5C, 0x7A, 0xAA, 0xB5, 0x6E, 0xCB, 0xD0, 0x0E, 0xAD, 0x6E, 0xAF, 0xEE, 0xF9, 0x88, 0x67, 0xBC, 0xDC, 0x3D, 0xAC, 0x60, 0xB8, 0x45, 0xF3, 0xB7, 0xBF, 0xC3, 0xDD, 0xA2, 0xBB, 0xAB, 0xCD, 0x89, 0x8F, 0x7F, 0xFE, 0x1F};
uint8_t spRED[] PROGMEM = {0x6A, 0xB5, 0xD9, 0x25, 0x4A, 0xE5, 0xDB, 0xC5, 0x4F, 0x6D, 0x88, 0x95, 0x2D, 0xD2, 0xB4, 0x8F, 0x2E, 0x37, 0x0E, 0x33, 0xCF, 0x7E, 0xAA, 0x9A, 0x5C, 0xC3, 0xB4, 0xCB, 0xA9, 0x86, 0x69, 0x76, 0xD3, 0x37, 0xB7, 0xBE, 0xCD, 0xED, 0xEF, 0xB4, 0xB7, 0xB0, 0x35, 0x69, 0x94, 0x22, 0x6D, 0x10, 0x28, 0x42, 0xB9, 0x8B, 0xC8, 0x06, 0x00, 0x50, 0xCF, 0x0E, 0xEE, 0x62, 0xEA, 0xA6, 0xBC, 0xC3, 0x14, 0xBB, 0x4A, 0x9F, 0xFA, 0xA5, 0xAF, 0x25, 0x13, 0x17, 0xDF, 0x9C, 0xBF, 0xFF, 0x07};
uint8_t spIS[] PROGMEM = {0xAD, 0xED, 0xD5, 0x58, 0xA4, 0x9E, 0xCE, 0x76, 0xF5, 0xDD, 0xAB, 0x29, 0xF5, 0xD2, 0xDD, 0xEF, 0x7E, 0x0C, 0xC3, 0xA9, 0x06, 0xFA, 0xD3, 0x32, 0x0F, 0x6E, 0x94, 0x22, 0x8F, 0xF3, 0x92, 0xF6, 0x05, 0x43, 0xCC, 0x74, 0x77, 0x3E, 0xC3, 0xF5, 0x95, 0x98, 0xA9, 0xBA, 0x8B, 0x8F, 0x00, 0x7E, 0x73, 0xE5, 0x00, 0x05, 0x28, 0xF0, 0xFF};
uint8_t spALERT[] PROGMEM = {0xA5, 0xCF, 0xC6, 0xAB, 0x55, 0x5B, 0xAF, 0x39, 0xDA, 0xC9, 0x54, 0xDD, 0xBC, 0xC6, 0xC2, 0x3C, 0x27, 0x20, 0xCF, 0x1C, 0xD7, 0x30, 0xB0, 0x45, 0x16, 0x69, 0x1D, 0xC3, 0x11, 0xE4, 0x59, 0x8A, 0x7C, 0xB5, 0x9B, 0x8B, 0xD9, 0x30, 0xB7, 0xD3, 0x76, 0x19, 0x9A, 0x25, 0x59, 0x57, 0x59, 0xEC, 0x11, 0xAF, 0xE8, 0xD9, 0xF9, 0x2A, 0x8A, 0x1D, 0xF0, 0x75, 0x3F, 0x73, 0xAC, 0x87, 0x3B, 0xA2, 0x0B, 0xAA, 0x2B, 0xCF, 0xE4, 0x10, 0xA1, 0xDC, 0x45, 0x64, 0x03, 0x00, 0x80, 0x01, 0x66, 0x36, 0x33, 0xC0, 0xAB, 0xD5, 0x0A, 0x68, 0x25, 0x85, 0x02, 0xFF, 0x0F};
//female voice for numbers and time
uint8_t spTHE[] PROGMEM = {
0x08,0xE8,0x3E,0x55,0x01,0xC3,0x86,0x27,0xAF,0x72,0x0D,0x4D,0x97,0xD5,0xBC,0x64,0x3C,0xF2,0x5C,0x51,0xF1,0x93,0x36,0x8F,0x4F,0x59,0x2A,0x42,0x7A,0x32,0xC3,0x64,0xFF,0x3F};
uint8_t spTIME[] PROGMEM = {
0x0E,0x28,0xAC,0x2D,0x01,0x5D,0xB6,0x0D,0x33,0xF3,0x54,0xB3,0x60,0xBA,0x8C,0x54,0x5C,0xCD,0x2D,0xD4,0x32,0x73,0x0F,0x8E,0x34,0x33,0xCB,0x4A,0x25,0xD4,0x25,0x83,0x2C,0x2B,0xD5,0x50,0x97,0x08,0x32,0xEC,0xD4,0xDC,0x4C,0x33,0xC8,0x70,0x73,0x0F,0x33,0xCD,0x20,0xC3,0xCB,0x43,0xDD,0x3C,0xCD,0x8C,0x20,0x77,0x89,0xF4,0x94,0xB2,0xE2,0xE2,0x35,0x22,0x5D,0xD6,0x4A,0x8A,0x96,0xCC,0x36,0x25,0x2D,0xC9,0x9A,0x7B,0xC2,0x18,0x87,0x24,0x4B,0x1C,0xC9,0x50,0x19,0x92,0x2C,0x71,0x34,0x4B,0x45,0x8A,0x8B,0xC4,0x96,0xB6,0x5A,0x29,0x2A,0x92,0x5A,0xCA,0x53,0x96,0x20,0x05,0x09,0xF5,0x92,0x5D,0xBC,0xE8,0x58,0x4A,0xDD,0xAE,0x73,0xBD,0x65,0x4B,0x8D,0x78,0xCA,0x2B,0x4E,0xD8,0xD9,0xED,0x22,0x20,0x06,0x75,0x00,0x00,0x80,0xFF,0x07};
0x21,0x18,0x96,0x38,0xB7,0x14,0x8D,0x60,0x3A,0xA6,0xE8,0x51,0xB4,0xDC,0x2E,0x48,0x7B,0x5A,0xF1,0x70,0x1B,0xA3,0xEC,0x09,0xC6,0xCB,0xEB,0x92,0x3D,0xA7,0x69,0x1F,0xAF,0x71,0x89,0x9C,0xA2,0xB3,0xFC,0xCA,0x35,0x72,0x9A,0xD1,0xF0,0xAB,0x12,0xB3,0x2B,0xC6,0xCD,0x4F,0xCC,0x32,0x26,0x19,0x07,0xDF,0x0B,0x8F,0xB8,0xA4,0xED,0x7C,0xCF,0x23,0x62,0x8B,0x8E,0xF1,0x23,0x0A,0x8B,0x6E,0xCB,0xCE,0xEF,0x54,0x44,0x3C,0xDC,0x08,0x60,0x0B,0x37,0x01,0x1C,0x53,0x26,0x80,0x15,0x4E,0x14,0xB0,0x54,0x2B,0x02,0xA4,0x69,0xFF,0x7F};
uint8_t spA_M_[] PROGMEM = {
0xCD,0xEF,0x86,0xAB,0x57,0x6D,0x0F,0xAF,0x71,0xAD,0x49,0x55,0x3C,0xFC,0x2E,0xC5,0xB7,0x5C,0xF1,0xF2,0x87,0x66,0xDD,0x4E,0xC5,0xC3,0xEF,0x92,0xE2,0x3A,0x65,0xB7,0xA0,0x09,0xAA,0x1B,0x97,0x54,0x82,0x2E,0x28,0x77,0x5C,0x52,0x09,0x1A,0xA3,0xB8,0x76,0x49,0x25,0x68,0x8C,0x73,0xDB,0x24,0x95,0xA0,0x32,0xA9,0x6B,0xA7,0xD9,0x82,0x26,0xA9,0x76,0x42,0xD6,0x08,0xBA,0xE1,0xE8,0x0E,0x5A,0x2B,0xEA,0x9E,0x3D,0x27,0x18,0xAD,0xA8,0x07,0xF1,0x98,0x90,0x35,0xA2,0x96,0x44,0xA3,0x5D,0x66,0x8B,0x6B,0x12,0xCD,0x32,0x85,0x25,0xC9,0x81,0x2D,0xC3,0x64,0x85,0x34,0x58,0x89,0x94,0x52,0x1C,0x52,0x2F,0x35,0xDA,0xC7,0x51,0x48,0x23,0x97,0xCC,0x2C,0x97,0x2E,0xF3,0x5C,0xF3,0xA2,0x14,0xBA,0x2C,0x48,0xCE,0xCA,0x76,0xE8,0x32,0x2F,0x34,0xB2,0xDB,0x85,0xC9,0x83,0x90,0xA8,0x2C,0x57,0x26,0x8F,0x9C,0xBD,0xA2,0x53,0xD9,0xC2,0x54,0x59,0x28,0x99,0x4B,0x2C,0x5D,0xFF,0x3F};
uint8_t spP_M_[] PROGMEM = {
0x0E,0x98,0x41,0x54,0x00,0x43,0xA0,0x05,0xAB,0x42,0x8E,0x1D,0xA3,0x15,0xEC,0x4E,0x58,0xF7,0x92,0x66,0x70,0x1B,0x66,0xDB,0x73,0x99,0xC1,0xEB,0x98,0xED,0xD6,0x25,0x25,0x6F,0x70,0x92,0xDD,0x64,0xD8,0xFC,0x61,0xD0,0x66,0x83,0xD6,0x0A,0x86,0x23,0xAB,0x69,0xDA,0x2B,0x18,0x9E,0x3D,0x37,0x69,0x9D,0xA8,0x07,0x71,0x9F,0xA0,0xBD,0xA2,0x16,0xD5,0x7C,0x54,0xF6,0x88,0x6B,0x54,0x8B,0x34,0x49,0x2D,0x29,0x49,0x3C,0x34,0x64,0xA5,0x24,0x1B,0x36,0xD7,0x72,0x13,0x92,0xA4,0xC4,0x2D,0xC3,0xB3,0x4B,0xA3,0x62,0x0F,0x2B,0x37,0x6E,0x8B,0x5A,0xD4,0x3D,0xDD,0x9A,0x2D,0x50,0x93,0xF6,0x4C,0xAA,0xB6,0xC4,0x85,0x3B,0xB2,0xB1,0xD8,0x93,0x20,0x4D,0x8F,0x24,0xFF,0x0F};
uint8_t spOH[] PROGMEM = {
0xC6,0xC9,0x71,0x5A,0xA2,0x92,0x14,0x2F,0x6E,0x97,0x9C,0x46,0x9D,0xDC,0xB0,0x4D,0x62,0x1B,0x55,0x70,0xDD,0x55,0xBE,0x0E,0x36,0xC1,0x33,0x37,0xA9,0xA7,0x51,0x1B,0xCF,0x3C,0xA5,0x9E,0x44,0xAC,0x3C,0x7D,0x98,0x7B,0x52,0x96,0x72,0x65,0x4B,0xF6,0x1A,0xD9,0xCA,0xF5,0x91,0x2D,0xA2,0x2A,0x4B,0xF7,0xFF,0x01};
uint8_t spOCLOCK[] PROGMEM = {
0x21,0x4E,0x3D,0xB8,0x2B,0x19,0xBB,0x24,0x0E,0xE5,0xEC,0x60,0xE4,0xF2,0x90,0x13,0xD4,0x2A,0x11,0x80,0x00,0x42,0x69,0x26,0x40,0xD0,0x2B,0x04,0x68,0xE0,0x4D,0x00,0x3A,0x35,0x35,0x33,0xB6,0x51,0xD9,0x64,0x34,0x82,0xB4,0x9A,0x63,0x92,0x55,0x89,0x52,0x5B,0xCA,0x2E,0x34,0x25,0x4E,0x63,0x28,0x3A,0x50,0x95,0x26,0x8D,0xE6,0xAA,0x64,0x58,0xEA,0x92,0xCE,0xC2,0x46,0x15,0x9B,0x86,0xCD,0x2A,0x2E,0x37,0x00,0x00,0x00,0x0C,0xC8,0xDD,0x05,0x01,0xB9,0x33,0x21,0xA0,0x74,0xD7,0xFF,0x07};
uint8_t spONE[] PROGMEM = {
0xCC,0x67,0x75,0x42,0x59,0x5D,0x3A,0x4F,0x9D,0x36,0x63,0xB7,0x59,0xDC,0x30,0x5B,0x5C,0x23,0x61,0xF3,0xE2,0x1C,0xF1,0xF0,0x98,0xC3,0x4B,0x7D,0x39,0xCA,0x1D,0x2C,0x2F,0xB7,0x15,0xEF,0x70,0x79,0xBC,0xD2,0x46,0x7C,0x52,0xE5,0xF1,0x4A,0x6A,0xB3,0x71,0x47,0xC3,0x2D,0x39,0x34,0x4B,0x23,0x35,0xB7,0x7A,0x55,0x33,0x8F,0x59,0xDC,0xA2,0x44,0xB5,0xBC,0x66,0x72,0x8B,0x64,0xF5,0xF6,0x98,0xC1,0x4D,0x42,0xD4,0x27,0x62,0x38,0x2F,0x4A,0xB6,0x9C,0x88,0x68,0xBC,0xA6,0x95,0xF8,0x5C,0xA1,0x09,0x86,0x77,0x91,0x11,0x5B,0xFF,0x0F};
uint8_t spTWO[] PROGMEM = {
0x0E,0x38,0x6E,0x25,0x00,0xA3,0x0D,0x3A,0xA0,0x37,0xC5,0xA0,0x05,0x9E,0x56,0x35,0x86,0xAA,0x5E,0x8C,0xA4,0x82,0xB2,0xD7,0x74,0x31,0x22,0x69,0xAD,0x1C,0xD3,0xC1,0xD0,0xFA,0x28,0x2B,0x2D,0x47,0xC3,0x1B,0xC2,0xC4,0xAE,0xC6,0xCD,0x9C,0x48,0x53,0x9A,0xFF,0x0F};
uint8_t spTHREE[] PROGMEM = {
0x02,0xD8,0x2E,0x9C,0x01,0xDB,0xA6,0x33,0x60,0xFB,0x30,0x01,0xEC,0x20,0x12,0x8C,0xE4,0xD8,0xCA,0x32,0x96,0x73,0x63,0x41,0x39,0x89,0x98,0xC1,0x4D,0x0D,0xED,0xB0,0x2A,0x05,0x37,0x0F,0xB4,0xA5,0xAE,0x5C,0xDC,0x36,0xD0,0x83,0x2F,0x4A,0x71,0x7B,0x03,0xF7,0x38,0x59,0xCD,0xED,0x1E,0xB4,0x6B,0x14,0x35,0xB7,0x6B,0x94,0x99,0x91,0xD5,0xDC,0x26,0x48,0x77,0x4B,0x66,0x71,0x1B,0x21,0xDB,0x2D,0x8A,0xC9,0x6D,0x88,0xFC,0x26,0x28,0x3A,0xB7,0x21,0xF4,0x1F,0xA3,0x65,0xBC,0x02,0x38,0xBB,0x3D,0x8E,0xF0,0x2B,0xE2,0x08,0xB7,0x34,0xFF,0x0F};
uint8_t spFOUR[] PROGMEM = {
0x0C,0x18,0xB6,0x9A,0x01,0xC3,0x75,0x09,0x60,0xD8,0x0E,0x09,0x30,0xA0,0x9B,0xB6,0xA0,0xBB,0xB0,0xAA,0x16,0x4E,0x82,0xEB,0xEA,0xA9,0xFA,0x59,0x49,0x9E,0x59,0x23,0x9A,0x27,0x3B,0x78,0x66,0xAE,0x4A,0x9C,0x9C,0xE0,0x99,0xD3,0x2A,0xBD,0x72,0x92,0xEF,0xE6,0x88,0xE4,0x45,0x4D,0x7E,0x98,0x2D,0x62,0x67,0x37,0xF9,0xA1,0x37,0xA7,0x6C,0x94,0xE4,0xC7,0x1E,0xDC,0x3C,0xA5,0x83,0x1F,0x8B,0xEB,0x52,0x0E,0x0E,0x7E,0x2E,0x4E,0xC7,0x31,0xD2,0x79,0xA5,0x3A,0x0D,0xD9,0xC4,0xFF,0x07};
uint8_t spFIVE[] PROGMEM = {
0x02,0xE8,0x3E,0x8C,0x01,0xDD,0x65,0x08,0x60,0x98,0x4C,0x06,0x34,0x93,0xCE,0x80,0xE6,0xDA,0x9A,0x14,0x6B,0xAA,0x47,0xD1,0x5E,0x56,0xAA,0x6D,0x56,0xCD,0x78,0xD9,0xA9,0x1C,0x67,0x05,0x83,0xE1,0xA4,0xBA,0x38,0xEE,0x16,0x86,0x9B,0xFA,0x60,0x87,0x5B,0x18,0x6E,0xEE,0x8B,0x1D,0x6E,0x61,0xB9,0x69,0x36,0x65,0xBA,0x8D,0xE5,0xE5,0x3E,0x1C,0xE9,0x0E,0x96,0x9B,0x5B,0xAB,0x95,0x2B,0x58,0x6E,0xCE,0xE5,0x3A,0x6A,0xF3,0xB8,0x35,0x84,0x7B,0x05,0xA3,0xE3,0x36,0xEF,0x92,0x19,0xB4,0x86,0xDB,0xB4,0x69,0xB4,0xD1,0x2A,0x4E,0x65,0x9A,0x99,0xCE,0x28,0xD9,0x85,0x71,0x4C,0x18,0x6D,0x67,0x47,0xC6,0x5E,0x53,0x4A,0x9C,0xB5,0xE2,0x85,0x45,0x26,0xFE,0x7F};
uint8_t spSIX[] PROGMEM = {
0x0E,0xD8,0xAE,0xDD,0x03,0x0E,0x38,0xA6,0xD2,0x01,0xD3,0xB4,0x2C,0xAD,0x6A,0x35,0x9D,0xB1,0x7D,0xDC,0xEE,0xC4,0x65,0xD7,0xF1,0x72,0x47,0x24,0xB3,0x19,0xD9,0xD9,0x05,0x70,0x40,0x49,0xEA,0x02,0x98,0xBE,0x42,0x01,0xDF,0xA4,0x69,0x40,0x00,0xDF,0x95,0xFC,0x3F};
uint8_t spSEVEN[] PROGMEM = {
0x02,0xB8,0x3A,0x8C,0x01,0xDF,0xA4,0x73,0x40,0x01,0x47,0xB9,0x2F,0x33,0x3B,0x73,0x5F,0x53,0x7C,0xEC,0x9A,0xC5,0x63,0xD5,0xD1,0x75,0xAE,0x5B,0xFC,0x64,0x5C,0x35,0x87,0x91,0xF1,0x83,0x36,0xB5,0x68,0x55,0xC5,0x6F,0xDA,0x45,0x2D,0x1C,0x2D,0xB7,0x38,0x37,0x9F,0x60,0x3C,0xBC,0x9A,0x85,0xA3,0x25,0x66,0xF7,0x8A,0x57,0x1C,0xA9,0x67,0x56,0xCA,0x5E,0xF0,0xB2,0x16,0xB2,0xF1,0x89,0xCE,0x8B,0x92,0x25,0xC7,0x2B,0x33,0xCF,0x48,0xB1,0x99,0xB4,0xF3,0xFF};
uint8_t spEIGHT[] PROGMEM = {
0xC3,0x6C,0x86,0xB3,0x27,0x6D,0x0F,0xA7,0x48,0x99,0x4E,0x55,0x3C,0xBC,0x22,0x65,0x36,0x4D,0xD1,0xF0,0x32,0xD3,0xBE,0x34,0xDA,0xC3,0xEB,0x82,0xE2,0xDA,0x65,0x35,0xAF,0x31,0xF2,0x6B,0x97,0x95,0xBC,0x86,0xD8,0x6F,0x82,0xA6,0x73,0x0B,0xC6,0x9E,0x72,0x99,0xCC,0xCB,0x02,0xAD,0x3C,0x9A,0x10,0x60,0xAB,0x62,0x05,0x2C,0x37,0x84,0x00,0xA9,0x73,0x00,0x00,0xFE,0x1F};
uint8_t spNINE[] PROGMEM = {
0xCC,0xA1,0x26,0xBB,0x83,0x93,0x18,0xCF,0x4A,0xAD,0x2E,0x31,0xED,0x3C,0xA7,0x24,0x26,0xC3,0x54,0xF1,0x92,0x64,0x8B,0x8A,0x98,0xCB,0x2B,0x2E,0x34,0x53,0x2D,0x0E,0x2F,0x57,0xB3,0x0C,0x0D,0x3C,0xBC,0x3C,0x4C,0x4B,0xCA,0xF4,0xF0,0x72,0x0F,0x6E,0x49,0x53,0xCD,0xCB,0x53,0x2D,0x35,0x4D,0x0F,0x2F,0x0F,0xD7,0x0C,0x0D,0x3D,0xBC,0xDC,0x4D,0xD3,0xDD,0xC2,0xF0,0x72,0x52,0x4F,0x57,0x9B,0xC3,0xAB,0x89,0xBD,0x42,0x2D,0x0F,0xAF,0x5A,0xD1,0x71,0x91,0x55,0xBC,0x2C,0xC5,0x3B,0xD8,0x65,0xF2,0x82,0x94,0x18,0x4E,0x3B,0xC1,0x73,0x42,0x32,0x33,0x15,0x45,0x4F,0x79,0x52,0x6A,0x55,0xA6,0xA3,0xFF,0x07};
uint8_t spTEN[] PROGMEM = {
0x0E,0xD8,0xB1,0xDD,0x01,0x3D,0xA8,0x24,0x7B,0x04,0x27,0x76,0x77,0xDC,0xEC,0xC2,0xC5,0x23,0x84,0xCD,0x72,0x9A,0x51,0xF7,0x62,0x45,0xC7,0xEB,0x4E,0x35,0x4A,0x14,0x2D,0xBF,0x45,0xB6,0x0A,0x75,0xB8,0xFC,0x16,0xD9,0x2A,0xD9,0xD6,0x0A,0x5A,0x10,0xCD,0xA2,0x48,0x23,0xA8,0x81,0x35,0x4B,0x2C,0xA7,0x20,0x69,0x0A,0xAF,0xB6,0x15,0x82,0xA4,0x29,0x3C,0xC7,0x52,0x08,0xA2,0x22,0xCF,0x68,0x4B,0x2E,0xF0,0x8A,0xBD,0xA3,0x2C,0xAB,0x40,0x1B,0xCE,0xAA,0xB2,0x6C,0x82,0x40,0x4D,0x7D,0xC2,0x89,0x88,0x8A,0x61,0xCC,0x74,0xD5,0xFF,0x0F};
uint8_t spELEVEN[] PROGMEM = {
0xC3,0xCD,0x76,0x5C,0xAE,0x14,0x0F,0x37,0x9B,0x71,0xDE,0x92,0x55,0xBC,0x2C,0x27,0x70,0xD3,0x76,0xF0,0x83,0x5E,0xA3,0x5E,0x5A,0xC1,0xF7,0x61,0x58,0xA7,0x19,0x35,0x3F,0x99,0x31,0xDE,0x52,0x74,0xFC,0xA2,0x26,0x64,0x4B,0xD1,0xF1,0xAB,0xAE,0xD0,0x2D,0xC5,0xC7,0x2F,0x36,0xDD,0x27,0x15,0x0F,0x3F,0xD9,0x08,0x9F,0x62,0xE4,0xC2,0x2C,0xD4,0xD8,0xD3,0x89,0x0B,0x1B,0x57,0x11,0x0B,0x3B,0xC5,0xCF,0xD6,0xCC,0xC6,0x64,0x35,0xAF,0x18,0x73,0x1F,0xA1,0x5D,0xBC,0x62,0x45,0xB3,0x45,0x51,0xF0,0xA2,0x62,0xAB,0x4A,0x5B,0xC9,0x4B,0x8A,0x2D,0xB3,0x6C,0x06,0x2F,0x29,0xB2,0xAC,0x8A,0x18,0xBC,0x28,0xD9,0xAA,0xD2,0x92,0xF1,0xBC,0xE0,0x98,0x8C,0x48,0xCC,0x17,0x52,0xA3,0x27,0x6D,0x93,0xD0,0x4B,0x8E,0x0E,0x77,0x02,0x00,0xFF,0x0F};
uint8_t spTWELVE[] PROGMEM = {
0x06,0x28,0x46,0xD3,0x01,0x25,0x06,0x13,0x20,0xBA,0x70,0x70,0xB6,0x79,0xCA,0x36,0xAE,0x28,0x38,0xE1,0x29,0xC5,0x35,0xA3,0xE6,0xC4,0x16,0x6A,0x53,0x8C,0x97,0x9B,0x72,0x86,0x4F,0x28,0x1A,0x6E,0x0A,0x59,0x36,0xAE,0x68,0xF8,0x29,0x67,0xFA,0x06,0xA3,0x16,0xC4,0x96,0xE6,0x53,0xAC,0x5A,0x9C,0x56,0x72,0x77,0x31,0x4E,0x49,0x5C,0x8D,0x5B,0x29,0x3B,0x24,0x61,0x1E,0x6C,0x9B,0x6C,0x97,0xF8,0xA7,0x34,0x19,0x92,0x4C,0x62,0x9E,0x72,0x65,0x58,0x12,0xB1,0x7E,0x09,0xD5,0x2E,0x53,0xC5,0xBA,0x36,0x6B,0xB9,0x2D,0x17,0x05,0xEE,0x9A,0x6E,0x8E,0x05,0x50,0x6C,0x19,0x07,0x18,0x50,0xBD,0x3B,0x01,0x92,0x08,0x41,0x40,0x10,0xA6,0xFF,0x0F};
uint8_t spTHIRTEEN[] PROGMEM = {
0x08,0xE8,0x2C,0x15,0x01,0x43,0x07,0x13,0xE0,0x98,0xB4,0xA6,0x35,0xA9,0x1E,0xDE,0x56,0x8E,0x53,0x9C,0x7A,0xE7,0xCA,0x5E,0x76,0x8D,0x94,0xE5,0x2B,0xAB,0xD9,0xB5,0x62,0xA4,0x9C,0xE4,0xE6,0xB4,0x41,0x1E,0x7C,0xB6,0x93,0xD7,0x16,0x99,0x5A,0xCD,0x61,0x76,0x55,0xC2,0x91,0x61,0x1B,0xC0,0x01,0x5D,0x85,0x05,0xE0,0x68,0x51,0x07,0x1C,0xA9,0x64,0x80,0x1D,0x4C,0x9C,0x95,0x88,0xD4,0x04,0x3B,0x4D,0x4E,0x21,0x5C,0x93,0xA8,0x26,0xB9,0x05,0x4B,0x6E,0xA0,0xE2,0xE4,0x57,0xC2,0xB9,0xC1,0xB2,0x93,0x5F,0x09,0xD7,0x24,0xCB,0x4E,0x41,0x25,0x54,0x1D,0x62,0x3B,0x05,0x8D,0x52,0x57,0xAA,0xAD,0x10,0x24,0x26,0xE3,0xE1,0x36,0x5D,0x10,0x85,0xB4,0x97,0x85,0x72,0x41,0x14,0x52,0x5E,0x1A,0xCA,0xF9,0x91,0x6B,0x7A,0x5B,0xC4,0xE0,0x17,0x2D,0x54,0x1D,0x92,0x8C,0x1F,0x25,0x4B,0x8F,0xB2,0x16,0x41,0xA1,0x4A,0x3E,0xE6,0xFA,0xFF,0x01};
uint8_t spFOURTEEN[] PROGMEM = {
0x0C,0x58,0xAE,0x5C,0x01,0xD9,0x87,0x07,0x51,0xB7,0x25,0xB3,0x8A,0x15,0x2C,0xF7,0x1C,0x35,0x87,0x4D,0xB2,0xDD,0x53,0xCE,0x28,0x2B,0xC9,0x0E,0x97,0x2D,0xBD,0x2A,0x17,0x27,0x76,0x8E,0xD2,0x9A,0x6C,0x80,0x94,0x71,0x00,0x00,0x02,0xB0,0x58,0x58,0x00,0x9E,0x0B,0x0A,0xC0,0xB2,0xCE,0xC1,0xC8,0x98,0x7A,0x52,0x95,0x24,0x2B,0x11,0xED,0x36,0xD4,0x92,0xDC,0x4C,0xB5,0xC7,0xC8,0x53,0xF1,0x2A,0xE5,0x1A,0x17,0x55,0xC5,0xAF,0x94,0xBB,0xCD,0x1C,0x26,0xBF,0x52,0x9A,0x72,0x53,0x98,0xFC,0xC2,0x68,0xD2,0x4D,0x61,0xF0,0xA3,0x90,0xB6,0xD6,0x50,0xC1,0x8F,0x42,0xDA,0x4A,0x43,0x39,0x3F,0x48,0x2D,0x6B,0x33,0xF9,0xFF};
uint8_t spFIFTEEN[] PROGMEM = {
0x08,0xE8,0x2A,0x0D,0x01,0xDD,0xBA,0x31,0x60,0x6A,0xF7,0xA0,0xAE,0x54,0xAA,0x5A,0x76,0x97,0xD9,0x34,0x69,0xEF,0x32,0x1E,0x66,0xE1,0xE2,0xB3,0x43,0xA9,0x18,0x55,0x92,0x4E,0x37,0x2D,0x67,0x6F,0xDF,0xA2,0x5A,0xB6,0x04,0x30,0x55,0xA8,0x00,0x86,0x09,0xE7,0x00,0x01,0x16,0x17,0x05,0x70,0x40,0x57,0xE5,0x01,0xF8,0x21,0x34,0x00,0xD3,0x19,0x33,0x80,0x89,0x9A,0x62,0x34,0x4C,0xD5,0x49,0xAE,0x8B,0x53,0x09,0xF7,0x26,0xD9,0x6A,0x7E,0x23,0x5C,0x13,0x12,0xB3,0x04,0x9D,0x50,0x4F,0xB1,0xAD,0x14,0x15,0xC2,0xD3,0xA1,0xB6,0x42,0x94,0xA8,0x8C,0x87,0xDB,0x74,0xB1,0x70,0x59,0xE1,0x2E,0xC9,0xC5,0x81,0x5B,0x55,0xA4,0x4C,0x17,0x47,0xC1,0x6D,0xE3,0x81,0x53,0x9C,0x84,0x6A,0x46,0xD9,0x4C,0x51,0x31,0x42,0xD9,0x66,0xC9,0x44,0x85,0x29,0x6A,0x9B,0xAD,0xFF,0x07};
uint8_t spSIXTEEN[] PROGMEM = {
0x0A,0x58,0x5A,0x5D,0x00,0x93,0x97,0x0B,0x60,0xA9,0x48,0x05,0x0C,0x15,0xAE,0x80,0xAD,0x3D,0x14,0x30,0x7D,0xD9,0x50,0x92,0x92,0xAC,0x0D,0xC5,0xCD,0x2A,0x82,0xAA,0x3B,0x98,0x04,0xB3,0x4A,0xC8,0x9A,0x90,0x05,0x09,0x68,0x51,0xD4,0x01,0x23,0x9F,0x1A,0x60,0xA9,0x12,0x03,0xDC,0x50,0x81,0x80,0x22,0xDC,0x20,0x00,0xCB,0x06,0x3A,0x60,0x16,0xE3,0x64,0x64,0x42,0xDD,0xCD,0x6A,0x8A,0x5D,0x28,0x75,0x07,0xA9,0x2A,0x5E,0x65,0x34,0xED,0x64,0xBB,0xF8,0x85,0xF2,0x94,0x8B,0xAD,0xE4,0x37,0x4A,0x5B,0x21,0xB6,0x52,0x50,0x19,0xAD,0xA7,0xD8,0x4A,0x41,0x14,0xDA,0x5E,0x12,0x3A,0x04,0x91,0x4B,0x7B,0x69,0xA8,0x10,0x24,0x2E,0xE5,0xA3,0x81,0x52,0x90,0x94,0x5A,0x55,0x98,0x32,0x41,0x50,0xCC,0x93,0x2E,0x47,0x85,0x89,0x1B,0x5B,0x5A,0x62,0x04,0x44,0xE3,0x02,0x80,0x80,0x64,0xDD,0xFF,0x1F};
uint8_t spSEVENTEEN[] PROGMEM = {
0x02,0x98,0x3A,0x42,0x00,0x5B,0xA6,0x09,0x60,0xDB,0x52,0x06,0x1C,0x93,0x29,0x80,0xA9,0x52,0x87,0x9A,0xB5,0x99,0x4F,0xC8,0x3E,0x46,0xD6,0x5E,0x7E,0x66,0xFB,0x98,0xC5,0x5A,0xC6,0x9A,0x9C,0x63,0x15,0x6B,0x11,0x13,0x8A,0x9C,0x97,0xB9,0x9A,0x5A,0x39,0x71,0xEE,0xD2,0x29,0xC2,0xA6,0xB8,0x58,0x59,0x99,0x56,0x14,0xA3,0xE1,0x26,0x19,0x19,0xE3,0x8C,0x93,0x17,0xB4,0x46,0xB5,0x88,0x71,0x9E,0x97,0x9E,0xB1,0x2C,0xC5,0xF8,0x56,0xC4,0x58,0xA3,0x1C,0xE1,0x33,0x9D,0x13,0x41,0x8A,0x43,0x58,0xAD,0x95,0xA9,0xDB,0x36,0xC0,0xD1,0xC9,0x0E,0x58,0x4E,0x45,0x01,0x23,0xA9,0x04,0x37,0x13,0xAE,0x4D,0x65,0x52,0x82,0xCA,0xA9,0x37,0x99,0x4D,0x89,0xBA,0xC0,0xBC,0x14,0x36,0x25,0xEA,0x1C,0x73,0x52,0x1D,0x97,0xB8,0x33,0xAC,0x0E,0x75,0x9C,0xE2,0xCE,0xB0,0xDA,0xC3,0x51,0x4A,0x1A,0xA5,0xCA,0x70,0x5B,0x21,0xCE,0x4C,0x26,0xD2,0x6C,0xBA,0x38,0x71,0x2E,0x1F,0x2D,0xED,0xE2,0x24,0xB8,0xBC,0x3D,0x52,0x88,0xAB,0x50,0x8E,0xA8,0x48,0x22,0x4E,0x42,0xA0,0x26,0x55,0xFD,0x3F};
uint8_t spEIGHTEEN[] PROGMEM = {
0x2E,0x9C,0xD1,0x4D,0x54,0xEC,0x2C,0xBF,0x1B,0x8A,0x99,0x70,0x7C,0xFC,0x2E,0x29,0x6F,0x52,0xF6,0xF1,0xBA,0x20,0xBF,0x36,0xD9,0xCD,0xED,0x0C,0xF3,0x27,0x64,0x17,0x73,0x2B,0xA2,0x99,0x90,0x65,0xEC,0xED,0x40,0x73,0x32,0x12,0xB1,0xAF,0x30,0x35,0x0B,0xC7,0x00,0xE0,0x80,0xAE,0xDD,0x1C,0x70,0x43,0xAA,0x03,0x86,0x51,0x36,0xC0,0x30,0x64,0xCE,0x4C,0x98,0xFB,0x5C,0x65,0x07,0xAF,0x10,0xEA,0x0B,0x66,0x1B,0xFC,0x46,0xA8,0x3E,0x09,0x4D,0x08,0x2A,0xA6,0x3E,0x67,0x36,0x21,0x2A,0x98,0x67,0x9D,0x15,0xA7,0xA8,0x60,0xEE,0xB6,0x94,0x99,0xA2,0x4A,0x78,0x22,0xC2,0xA6,0x8B,0x8C,0x8E,0xCC,0x4C,0x8A,0x2E,0x8A,0x4C,0xD3,0x57,0x03,0x87,0x28,0x71,0x09,0x1F,0x2B,0xE4,0xA2,0xC4,0xC5,0x6D,0xAD,0x54,0x88,0xB2,0x63,0xC9,0xF2,0x50,0x2E,0x8A,0x4A,0x38,0x4A,0xEC,0x88,0x28,0x08,0xE3,0x28,0x49,0xF3,0xFF};
uint8_t spNINETEEN[] PROGMEM = {
0xC2,0xEA,0x8A,0x95,0x2B,0x6A,0x05,0x3F,0x71,0x71,0x5F,0x0D,0x12,0xFC,0x28,0x25,0x62,0x35,0xF0,0xF0,0xB3,0x48,0x1E,0x0F,0xC9,0xCB,0x2F,0x45,0x7C,0x2C,0x25,0x1F,0xBF,0x14,0xB3,0x2C,0xB5,0x75,0xFC,0x5A,0x5C,0xA3,0x5D,0xE1,0xF1,0x7A,0x76,0xB3,0x4E,0x45,0xC7,0xED,0x96,0x23,0x3B,0x18,0x37,0x7B,0x18,0xCC,0x09,0x51,0x13,0x4C,0xAB,0x6C,0x4C,0x4B,0x96,0xD2,0x49,0xAA,0x36,0x0B,0xC5,0xC2,0x20,0x26,0x27,0x35,0x63,0x09,0x3D,0x30,0x8B,0xF0,0x48,0x5C,0xCA,0x61,0xDD,0xCB,0xCD,0x91,0x03,0x8E,0x4B,0x76,0xC0,0xCC,0x4D,0x06,0x98,0x31,0x31,0x98,0x99,0x70,0x6D,0x2A,0xA3,0xE4,0x16,0xCA,0xBD,0xCE,0x5C,0x92,0x57,0x28,0xCF,0x09,0x69,0x2E,0x7E,0xA5,0x3C,0x63,0xA2,0x30,0x05,0x95,0xD2,0x74,0x98,0xCD,0x14,0x54,0xCA,0x53,0xA9,0x96,0x52,0x50,0x28,0x6F,0xBA,0xCB,0x0C,0x41,0x50,0xDE,0x65,0x2E,0xD3,0x05,0x89,0x4B,0x7B,0x6B,0x20,0x17,0x44,0xAE,0xED,0x23,0x81,0x52,0x90,0x85,0x73,0x57,0xD0,0x72,0x41,0xB1,0x02,0xDE,0x2E,0xDB,0x04,0x89,0x05,0x79,0xBB,0x62,0xE5,0x76,0x11,0xCA,0x61,0x0E,0xFF,0x1F};
uint8_t spTWENTY[] PROGMEM = {
0x01,0x98,0xD1,0xC2,0x00,0xCD,0xA4,0x32,0x20,0x79,0x13,0x04,0x28,0xE7,0x92,0xDC,0x70,0xCC,0x5D,0xDB,0x76,0xF3,0xD2,0x32,0x0B,0x0B,0x5B,0xC3,0x2B,0xCD,0xD4,0xDD,0x23,0x35,0xAF,0x44,0xE1,0xF0,0xB0,0x6D,0x3C,0xA9,0xAD,0x3D,0x35,0x0E,0xF1,0x0C,0x8B,0x28,0xF7,0x34,0x01,0x68,0x22,0xCD,0x00,0xC7,0xA4,0x04,0xBB,0x32,0xD6,0xAC,0x56,0x9C,0xDC,0xCA,0x28,0x66,0x53,0x51,0x70,0x2B,0xA5,0xBC,0x0D,0x9A,0xC1,0xEB,0x14,0x73,0x37,0x29,0x19,0xAF,0x33,0x8C,0x3B,0xA7,0x24,0xBC,0x42,0xB0,0xB7,0x59,0x09,0x09,0x3C,0x96,0xE9,0xF4,0x58,0xFF,0x0F};
uint8_t spTHIRTY[] PROGMEM = {
0x08,0x98,0xD6,0x15,0x01,0x43,0xBB,0x0A,0x20,0x1B,0x8B,0xE5,0x16,0xA3,0x1E,0xB6,0xB6,0x96,0x97,0x3C,0x57,0xD4,0x2A,0x5E,0x7E,0x4E,0xD8,0xE1,0x6B,0x7B,0xF8,0x39,0x63,0x0D,0x9F,0x95,0xE1,0xE7,0x4C,0x76,0xBC,0x91,0x5B,0x90,0x13,0xC6,0x68,0x57,0x4E,0x41,0x8B,0x10,0x5E,0x1D,0xA9,0x44,0xD3,0xBA,0x47,0xB8,0xDD,0xE4,0x35,0x86,0x11,0x93,0x94,0x92,0x5F,0x29,0xC7,0x4C,0x30,0x0C,0x41,0xC5,0x1C,0x3B,0x2E,0xD3,0x05,0x15,0x53,0x6C,0x07,0x4D,0x15,0x14,0x8C,0xB5,0xC9,0x6A,0x44,0x90,0x10,0x4E,0x9A,0xB6,0x21,0x81,0x23,0x3A,0x91,0x91,0xE8,0xFF,0x01};
uint8_t spFOURTY[] PROGMEM = {
0x04,0x18,0xB6,0x4C,0x00,0xC3,0x56,0x30,0xA0,0xE8,0xF4,0xA0,0x98,0x99,0x62,0x91,0xAE,0x83,0x6B,0x77,0x89,0x78,0x3B,0x09,0xAE,0xBD,0xA6,0x1E,0x63,0x3B,0x79,0x7E,0x71,0x5A,0x8F,0x95,0xE6,0xA5,0x4A,0x69,0xB9,0x4E,0x8A,0x5F,0x12,0x56,0xE4,0x58,0x69,0xE1,0x36,0xA1,0x69,0x2E,0x2B,0xF9,0x95,0x93,0x55,0x17,0xED,0xE4,0x37,0xC6,0xBA,0x93,0xB2,0x92,0xDF,0x19,0xD9,0x6E,0xC8,0x0A,0xFE,0x60,0xE8,0x37,0x21,0xC9,0xF9,0x8D,0x61,0x5F,0x32,0x13,0xE7,0x17,0x4C,0xD3,0xC6,0xB1,0x94,0x97,0x10,0x8F,0x8B,0xAD,0x11,0x7E,0xA1,0x9A,0x26,0x92,0xF6,0xFF,0x01};
uint8_t spFIFTY[] PROGMEM = {
0x08,0xE8,0x2E,0x84,0x00,0x23,0x84,0x13,0x60,0x38,0x95,0xA5,0x0F,0xCF,0xE2,0x79,0x8A,0x8F,0x37,0x02,0xB3,0xD5,0x2A,0x6E,0x5E,0x93,0x94,0x79,0x45,0xD9,0x05,0x5D,0x0A,0xB9,0x97,0x63,0x02,0x74,0xA7,0x82,0x80,0xEE,0xC3,0x10,0xD0,0x7D,0x28,0x03,0x6E,0x14,0x06,0x70,0xE6,0x0A,0xC9,0x9A,0x4E,0x37,0xD9,0x95,0x51,0xCE,0xBA,0xA2,0x14,0x0C,0x81,0x36,0x1B,0xB2,0x5C,0x30,0x38,0xFA,0x9C,0xC9,0x32,0x41,0xA7,0x18,0x3B,0xA2,0x48,0x04,0x05,0x51,0x4F,0x91,0x6D,0x12,0x04,0x20,0x9B,0x61,0x89,0xFF,0x1F};
uint8_t spGOOD[] PROGMEM = {
0x0A,0x28,0xCD,0x34,0x20,0xD9,0x1A,0x45,0x74,0xE4,0x66,0x24,0xAD,0xBA,0xB1,0x8C,0x9B,0x91,0xA5,0x64,0xE6,0x98,0x21,0x16,0x0B,0x96,0x9B,0x4C,0xE5,0xFF,0x01};
uint8_t spMORNING[] PROGMEM = {
0xCE,0x08,0x52,0x2A,0x35,0x5D,0x39,0x53,0x29,0x5B,0xB7,0x0A,0x15,0x0C,0xEE,0x2A,0x42,0x56,0x66,0xD2,0x55,0x2E,0x37,0x2F,0xD9,0x45,0xB3,0xD3,0xC5,0xCA,0x6D,0x27,0xD5,0xEE,0x50,0xF5,0x50,0x94,0x14,0x77,0x2D,0xD8,0x5D,0x49,0x92,0xFD,0xB1,0x64,0x2F,0xA9,0x49,0x0C,0x93,0x4B,0xAD,0x19,0x17,0x3E,0x66,0x1E,0xF1,0xA2,0x5B,0x84,0xE2,0x29,0x8F,0x8B,0x72,0x10,0xB5,0xB1,0x2E,0x4B,0xD4,0x45,0x89,0x4A,0xEC,0x5C,0x95,0x14,0x2B,0x8A,0x9C,0x34,0x52,0x5D,0xBC,0xCC,0xB5,0x3B,0x49,0x69,0x89,0x87,0xC1,0x98,0x56,0x3A,0x21,0x2B,0x82,0x67,0xCC,0x5C,0x85,0xB5,0x4A,0x8A,0xF6,0x64,0xA9,0x96,0xC4,0x69,0x3C,0x52,0x81,0x58,0x1C,0x97,0xF6,0x0E,0x1B,0xCC,0x0D,0x42,0x32,0xAA,0x65,0x12,0x67,0xD4,0x6A,0x61,0x52,0xFC,0xFF};
uint8_t spAFTERNOON[] PROGMEM = {
0xC7,0xCE,0xCE,0x3A,0xCB,0x58,0x1F,0x3B,0x07,0x9D,0x28,0x71,0xB4,0xAC,0x9C,0x74,0x5A,0x42,0x55,0x33,0xB2,0x93,0x0A,0x09,0xD4,0xC5,0x9A,0xD6,0x44,0x45,0xE3,0x38,0x60,0x9A,0x32,0x05,0xF4,0x18,0x01,0x09,0xD8,0xA9,0xC2,0x00,0x5E,0xCA,0x24,0xD5,0x5B,0x9D,0x4A,0x95,0xEA,0x34,0xEE,0x63,0x92,0x5C,0x4D,0xD0,0xA4,0xEE,0x58,0x0C,0xB9,0x4D,0xCD,0x42,0xA2,0x3A,0x24,0x37,0x25,0x8A,0xA8,0x8E,0xA0,0x53,0xE4,0x28,0x23,0x26,0x13,0x72,0x91,0xA2,0x76,0xBB,0x72,0x38,0x45,0x0A,0x46,0x63,0xCA,0x69,0x27,0x39,0x58,0xB1,0x8D,0x60,0x1C,0x34,0x1B,0x34,0xC3,0x55,0x8E,0x73,0x45,0x2D,0x4F,0x4A,0x3A,0x26,0x10,0xA1,0xCA,0x2D,0xE9,0x98,0x24,0x0A,0x1E,0x6D,0x97,0x29,0xD2,0xCC,0x71,0xA2,0xDC,0x86,0xC8,0x12,0xA7,0x8E,0x08,0x85,0x22,0x8D,0x9C,0x43,0xA7,0x12,0xB2,0x2E,0x50,0x09,0xEF,0x51,0xC5,0xBA,0x28,0x58,0xAD,0xDB,0xE1,0xFF,0x03};
uint8_t spEVENING[] PROGMEM = {
0xCD,0x6D,0x98,0x73,0x47,0x65,0x0D,0x6D,0x10,0xB2,0x5D,0x93,0x35,0x94,0xC1,0xD0,0x76,0x4D,0x66,0x93,0xA7,0x04,0xBD,0x71,0xD9,0x45,0xAE,0x92,0xD5,0xAC,0x53,0x07,0x6D,0xA5,0x76,0x63,0x51,0x92,0xD4,0xA1,0x83,0xD4,0xCB,0xB2,0x51,0x88,0xCD,0xF5,0x50,0x45,0xCE,0xA2,0x2E,0x27,0x28,0x54,0x15,0x37,0x0A,0xCF,0x75,0x61,0x5D,0xA2,0xC4,0xB5,0xC7,0x44,0x55,0x8A,0x0B,0xA3,0x6E,0x17,0x95,0x21,0xA9,0x0C,0x37,0xCD,0x15,0xBA,0xD4,0x2B,0x6F,0xB3,0x54,0xE4,0xD2,0xC8,0x64,0xBC,0x4C,0x91,0x49,0x12,0xE7,0xB2,0xB1,0xD0,0x22,0x0D,0x9C,0xDD,0xAB,0x62,0xA9,0x38,0x53,0x11,0xA9,0x74,0x2C,0xD2,0xCA,0x59,0x34,0xA3,0xE5,0xFF,0x03};
#include "talkie.c"
void sayNumber(long n) {
int tens;
if (n>19) {
tens = n / 10;
switch (tens) {
case 2:
Say(spTWENTY);
break;
case 3:
Say(spTHIRTY);
break;
case 4:
Say(spFOURTY);
break;
case 5:
Say(spFIFTY);
break;
n %= 10;
switch(n) {
case 0:
// Say(spOH);
break;
case 1:
Say(spONE);
break;
case 2:
Say(spTWO);
break;
case 3:
Say(spTHREE);
break;
case 4:
Say(spFOUR);
break;
case 5:
Say(spFIVE);
break;
case 6:
Say(spSIX);
break;
case 7:
Say(spSEVEN);
break;
case 8:
Say(spEIGHT);
break;
case 9:
Say(spNINE);
break;
case 10:
Say(spTEN);
break;
case 11:
Say(spELEVEN);
break;
case 12:
Say(spTWELVE);
break;
case 13:
Say(spTHIRTEEN);
break;
case 14:
Say(spFOURTEEN);
break;
case 15:
Say(spFIFTEEN);
break;
case 16:
Say(spSIXTEEN);
break;
case 17:
Say(spSEVENTEEN);
break;
case 18:
Say(spEIGHTEEN);
break;
case 19:
Say(spNINETEEN);
break;
int main() {
char i;
DDRB |= (1<<PB3); //PWM output OC2A -- MISO, so disconnect speaker before programming!
delay(1000);
while(1) {
Say(spGOOD);
Say(spEVENING);
delay(300);
Say(spTHE);
Say(spTIME);
Say(spIS);
sayNumber(19);
sayNumber(24);
delay(1000);
for(i=1; i<24; i++) {
sayNumber(i);
delay(1000);
