Slow down the servos
I’ve been trying to slow down the servos for some time. They’re supposed to slow down, too. They move much too fast. But no matter what value I enter, it doesn’t work. When I move the controller and the dot appears afterward, it seems to be working correctly. However, that’s not happening in the actual execution. The servos don’t slow down. Am I always forgetting something?
<!--Pololu Maestro servo controller settings file, http://www.pololu.com/catalog/product/1350-->
<UscSettings version="1">
  <NeverSuspend>false</NeverSuspend>
  <SerialMode>UART_FIXED_BAUD_RATE</SerialMode>
  <FixedBaudRate>9600</FixedBaudRate>
  <SerialTimeout>0</SerialTimeout>
  <EnableCrc>false</EnableCrc>
  <SerialDeviceNumber>12</SerialDeviceNumber>
  <SerialMiniSscOffset>0</SerialMiniSscOffset>
  <Channels ServosAvailable="6" ServoPeriod="234">
    <!--Period = 29,952 ms-->
    <!--Channel 0-->
    <Channel name="" mode="Servo" min="6464" max="6912" homemode="Off" home="6464" speed="20" acceleration="255" neutral="6464" range="1905" />
    <!--Channel 1-->
    <Channel name="" mode="Servo" min="3968" max="8000" homemode="Off" home="7040" speed="50" acceleration="50" neutral="7040" range="1905" />
    <!--Channel 2-->
    <Channel name="" mode="Servo" min="6016" max="7040" homemode="Off" home="6016" speed="10" acceleration="50" neutral="6016" range="1905" />
    <!--Channel 3-->
    <Channel name="" mode="Servo" min="3968" max="8000" homemode="Off" home="3968" speed="0" acceleration="0" neutral="6000" range="1905" />
    <!--Channel 4-->
    <Channel name="" mode="Servo" min="3968" max="8000" homemode="Ignore" home="3968" speed="0" acceleration="0" neutral="3968" range="1905" />
    <!--Channel 5-->
  </Channels>
  <Sequences>
    <Sequence name="Sequence 0">
      <Frame name="Frame 0" duration="500">6912 8000 7040 0 0 0</Frame>
      <Frame name="Frame 1" duration="500">6468 8000 7040 0 0 0</Frame>
      <Frame name="Frame 2" duration="500">6468 8000 7040 0 0 0</Frame>
      <Frame name="Frame 3" duration="500">6468 8000 7040 0 0 0</Frame>
      <Frame name="Frame 4" duration="500">6468 8000 6393 0 0 0</Frame>
      <Frame name="Frame 5" duration="500">6468 8000 6393 0 0 0</Frame>
      <Frame name="Frame 6" duration="500">6468 8000 6393 0 0 0</Frame>
      <Frame name="Frame 7" duration="500">6905 8000 7040 0 0 0</Frame>
      <Frame name="Frame 8" duration="500">6905 8000 7040 0 0 0</Frame>
      <Frame name="Frame 9" duration="500">6905 8000 7040 0 0 0</Frame>
    </Sequence>
    <Sequence name="Sequence 1">
      <Frame name="Frame 0" duration="2000">6912 8000 6398 0 0 0</Frame>
      <Frame name="Frame 1" duration="2000">6912 8000 6398 0 0 0</Frame>
      <Frame name="Frame 2" duration="2000">6912 8000 6398 0 0 0</Frame>
      <Frame name="Frame 3" duration="2000">6464 8000 6398 0 0 0</Frame>
      <Frame name="Frame 4" duration="2000">6464 8000 6398 0 0 0</Frame>
      <Frame name="Frame 5" duration="2000">6464 8000 6398 0 0 0</Frame>
      <Frame name="Frame 6" duration="2000">6912 8000 7040 0 0 0</Frame>
      <Frame name="Frame 7" duration="2000">6912 8000 7040 0 0 0</Frame>
      <Frame name="Frame 8" duration="2000">6912 8000 7040 0 0 0</Frame>
      <Frame name="Frame 9" duration="2000">6912 8000 7040 0 0 0</Frame>
    </Sequence>
    <Sequence name="Sequence 2">
      <Frame name="Frame 0" duration="500">6464 8000 7040 0 0 0</Frame>
      <Frame name="Frame 1" duration="500">6464 8000 7040 0 0 0</Frame>
      <Frame name="Frame 2" duration="500">6912 8000 7040 0 0 0</Frame>
      <Frame name="Frame 3" duration="500">6912 8000 7040 0 0 0</Frame>
      <Frame name="Frame 4" duration="500">6912 8000 6592 0 0 0</Frame>
      <Frame name="Frame 5" duration="500">6912 8000 6592 0 0 0</Frame>
      <Frame name="Frame 6" duration="500">6566 8000 6592 0 0 0</Frame>
      <Frame name="Frame 7" duration="500">6566 8000 6592 0 0 0</Frame>
      <Frame name="Frame 8" duration="500">6912 8000 7040 0 0 0</Frame>
      <Frame name="Frame 9" duration="500">6912 8000 7040 0 0 0</Frame>
    </Sequence>
  </Sequences>
  <Script ScriptDone="false">
### Sequence subroutines: ###
# Sequence 0
sub Sequence_0
  2000 6912 8000 7040 0 0 0 frame_0..5 # Frame 0
  2000 6468 frame_0 # Frame 1
  30000 delay # Frame 2
  2000 delay # Frame 3
  2000 6393 frame_2 # Frame 4
  30000 delay # Frame 5
  2000 delay # Frame 6
  2000 6905 7040 frame_0_2 # Frame 7
  30000 delay # Frame 8
  20000 delay # Frame 9
  30000 delay
  20000 delay
# Sequence 1
sub Sequence_1
  2000 6912 8000 6398 0 0 0 frame_0..5 # Frame 0
  30000 delay # Frame 1
  2000 delay # Frame 2
  2000 6464 frame_0 # Frame 3
  30000 delay # Frame 4
  2000 delay # Frame 5
  2000 6912 7040 frame_0_2 # Frame 6
  20000 delay # Frame 7
  30000 delay # Frame 9
  30000 delay
# Sequence 2
sub Sequence_2
  2000 6464 8000 7040 0 0 0 frame_0..5 # Frame 0
  2000 6912 frame_0 # Frame 2
  30000 delay # Frame 3
  2000 6592 frame_2 # Frame 4
  2000 6566 frame_0 # Frame 6
  30000 delay # Frame 7
  2000 6912 7040 frame_0_2 # Frame 8
  20000 delay
  30000 delay
  20000 delay
  30000 delay
  return
sub frame_0..5
  5 servo
  4 servo
  3 servo
  2 servo
  1 servo
  0 servo
  delay
  return
sub frame_0
  0 servo
  delay
  return
sub frame_2
  2 servo
  delay
  return
sub frame_0_2
  2 servo
  0 servo
  delay
  return
</Script>
</UscSettings>
I do not see any issues with your Maestro settings. However, it does look like most of your servos are making fairly small movements. You might try configuring much lower speeds (e.g. 3 instead of 50) and see if that is more appropriate for your application.
Please note that the speed and acceleration settings will not be used for the first movement after a servo is activated (for example, when the Maestro boots up), but they should apply to all subsequent movements.
