I am using a script (see attached) to control a servo that turns a valve. When the valve is moved to the desired position, I would like to put the servo (on channel 3) to sleep with the “0 3 servo” statement in the move_sub subroutine right after the get_moving_state loop so it doesn’t struggle against any load which could burn it out. David Grayson suggested this versus using a power relay that is turned on and off.
My problem is the sleep statement works with a JR Z9100HVT, but not a HiTec HS-7980TH. Any help with this? Is it that some servos respect the command and others don’t? Thank you.
Chuck Lob
Harken, Inc.
H-61395.txt (6.96 KB)
