Cannot get ShiftBars to work. Copied sample code from macetech.com site. Wired up as per sample wiring diagram. Driving a 2m strip of analog 5060 RGB LEDs (60 per meter) powered from a 300W supply. LEDs come on all white and stay on, no matter what the code says. Have tried with a single ShiftBar and up to 5 in the chain, no difference. Using Pololu 6-wire harnesses to connect them all. Help!
Removed the LED strips and placed a single LED on each of the ShiftBar outputs, no change. All 3 outputs come on full and stay on all the time, except when uploading code to the Arduino.
I am sorry you are having trouble controlling your ShiftBar. Can you tell me more about your setup? What LEDs are you trying to control? (It would be useful to have a link to a product page or a datasheet.) What sample code are you running? What is the voltage you are supplying from your power supply? Can you post pictures that clearly show how you have everything connected?
-Jon
Turned out to be a faulty Arduino board.
