This is the “mouse” 3pi with two SHARP GPY0A21 sensors connected in ADC6 (battery) and ADC7 (trimpot) and the main()
C program that makes dodge obstacles.
ullE (LEFT eye) ullD (RIGHT eye)
motorE (motor1) motorD (motor2)
int main()
set_analog_mode(MODE_10_BIT);
emitters_off();
// inicializacio del 3pi
initialize(); // Musica y pushbutton B
clear(); // LCD
// Bucle principal.
lcd_goto_xy(0,0);
print ("Esq.Dre.");
while(1)
// valor max.= 630 a 5 cm y min = 38 a mes de 80cm
if (!analog_is_converting())
ullE = analog_read(6); // es bateria
lcd_goto_xy(0,1);
print_long(ullE);
ullE = sqrt(ullE);
motorE = 120-9*ullE/2; // valors entre 25 i 5
ullD = analog_read(7); // es trimpot
lcd_goto_xy(4,1);
print_long(ullD);
ullD = sqrt(ullD);
motorD = 120-9*ullD/2;
if (ullD > 23 && ullE > 23) // tira enrera obstacle enfront colision
for(counter=20;counter<45;counter++)
motorD = -counter;
motorE = -counter;
set_motors(motorD, motorE);
red_led(1);
delay_ms(100);
red_led(0);
set_motors(0,0);
if (ullD < 12 && ullE < 12) // per anar recte ----
motorD = motorE;
set_motors(motorD,motorE); // !!! motors cambiats !!!!
delay_ms(100);
