Hi !
Does the 8 serial controler device SSC04 ,keep all parameter like : Range , speed , neutral , and can be disconnect to be stocking in a workshop without any power ?
Or does need receive all the setting parameter when we connect it to the computer all the time ?
I explain it , i want build a setting soft for the device ,and setting speed ,range , neutral ,disconect it stocking in my workshop.
And use another soft for just control the device preseted .
Thank you
Unfortunately, you cannot save your settings with this servo controller; it must be connected to a computer or microcontroller which sends the serial commands it needs to operate.
For better performance and the ability to save command sequences, you might consider our Maestro USB Servo Controllers.
-Derrill
Ok thank for your reply Derril.
I will use the polulu protocol with Usb model, for this fonction.
Thank for this info.
Just for thank for a second times !
The micro maestro work fine with my configuration ,
I set all essential parameters in USB mode,like range and speed in the polulu soft utilitarie , and work in Uart mode (to can expand the signal ,for a Rov ) with my proper application .
Thank you for your Help Derill!
