Hi, I am wondering if someone can help. I have a problem using arduino Servo library. I have arduino Uno R3 board. To inject PWM to ESC to run a brushless motor.
When I use FreqCount library + Servo Library , it does not work. I been searching every corner of the internet to find a solution. The problem is that, the timer1 is used on both library that causing the issue.
I have found few posts on the internet suggesting to use ServoTimer2 library. Which I have installed and was trying to use it like Servo library. If I use the same code for Servo.h , it works fine, but does not work for ServoTimer2.h.
But there is a compilation error.
here is my code
#include <ServoTimer2.h>
#define esc_pin 6
#define pot_input_pin A0
int pot_value;
int pwm_frequency;
int min_pulse_width = 1000;
int max_pulse_width = 2000;
ServoTimer2 PWM;
void setup() {
// put your setup code here, to run once:
pinMode(esc_pin, OUTPUT);
pinMode(pot_input_pin, INPUT);
PWM.attach(esc_pin, min_pulse_width, max_pulse_width);
Serial.begin(9600);
void loop() {
// put your main code here, to run repeatedly:
pot_value = analogRead(pot_input_pin);
pwm_frequency = map(pot_value, 0, 1023, 0, 180);
PWM.write(pwm_frequency);
Serial.print(pwm_frequency);
delay(500);
errors
C:\Users\OLI~1.AHM\AppData\Local\Temp\cc5XJxoo.ltrans0.ltrans.o: In function `setup':
C:\Users\Misc\Arduino Giga R1\Sketch\ServoTimer2_Sketch/ServoTimer2_Sketch.ino:19: undefined reference to `ServoTimer2::attach(int, int, int)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
