Installed the software as instructed. Win 7 shows device is working properly. Device manager shows no errors on the ports.
Maestro Control Center shows no errors and is connected.
Leds on device: Green led rapidly blinking, yellow led off…then two quick blinks…off then two quick blinks.
USB connected for communication. 6v power supply (4 AA) batteries connected to the power input screws. Verified with multimeter. HD 1800A servo connected to channel 0 with signal wire toward the interior of the device (per pinout diagram)
When I drag the slider back and forth I get no response at all. I’ve tried all the different serial modes. I tried different servos, analog as well as digital in channel 12. I set VSRV=VIN as per the manual for a single power supply. I’ve run out of ideas. Anything obvious stick out in my description? Help!!
Uggg. Murphy’s law. I have no idea what I did different, maybe just letting it sit overnight. But it’s now working seemingly fine. I think maybe my power supply was not functioning perfect. All good now. Thanks
