I have my pololu maestro hooked up and all is running perfect. The one weirdness is that if I move the servo across the range of motion and stop it there will be a weird vibrating or humming noise at random locations.
This doesn’t happen at the far end of ranges or at a certain spot, it happens in seemingly every other location on the range of motion. If I stop the servo and it makes the noise I can move it a little and it will stop, regardless of the load on the servo etc…
Hope I gave you enough info to help me.
Thanks
