I have been working on building an ROV. The system uses the following components
PIC 16F877A
RS232 to 485 convertors
Pololu Servo controller
standard speend controller (15Amp each)
So basically the PIC converts joystick analogue signals into digital which then passes the the data to the onboard USART, transmits to the ROV is then coverted into PWM by the Servo controller to drive the motors.
Here’s the problem…the A/D conversion takes place ( I can see the changes from the hooked up LCD) the Pololu controller recieves the data (green LED flashes), but there is no movement at the attached the servo.
I have used the mini SC protocol
TABLE_INDEX EQU 0x021 ; Index to table strings
COUNT EQU 0x022 ; A counter
DELAY EQU 0x023 ; Used in DELAYxxx routines
X_DELAY EQU 0x024 ; Used in X_DELAYxxx routines
COUNT2 EQU 0x025
Hundreds EQU 0x026
Tens EQU 0x027
Ones EQU 0x028
BIN EQU 0X029
Result1 EQU 2AH ;16bits for result data store
Result2 EQU 2BH
Result3 EQU 2CH
Result4 EQU 2DH
Preamble EQU 2EH ;pre-code for transmition
MOTOR1 EQU .9 ;motor number1 for transmition
MOTOR2 EQU .10
MOTOR3 EQU .11
MOTOR4 EQU .12
PREAMBLE EQU .255
w_temp EQU 0xA0 ; variable used for context saving
;w_temp1 EQU 0xA1 ; reserve bank1 equivalent of w_temp
; Program start
; This is the Periperal Interrupt routine. Should NOT get here
ORG 0x000 ; processor reset vector
nop ; nop required for icd
goto START ; go to beginning of program
ORG 0x004 ; interrupt vector location
; Initialize processor registers
START ; POWER_ON Reset (Beginning of program)
BSF STATUS,RP0 ;Bank1
MOVLW B'11111111'
MOVWF TRISA ;PortA is input
MOVLW B'00000000'
MOVWF TRISB ;PortB is output for 8 bit LCD
BSF OPTION_REG, NOT_RBPU ; Disable PORTB pull-ups
MOVLW B'01111111'
MOVWF TRISC ;PortC is I/O RS232 & data select for LCD
MOVLW B'00000000' ;Set PortD as input for light switches etc
MOVWF TRISD
MOVLW D'25' ;SET UP BAUD RATE 9600 4MHZ
MOVWF SPBRG
MOVLW B'10100110' ;SET UP TRXT REGISTER
MOVWF TXSTA
MOVLW B'10010000' ;SET UP RCV REGISTER
MOVWF RCSTA
MOVLW B'01001011'
MOVWF ADCON1 ;PortA bits 0-7 ANALOGUE WITH REF ON AD2 & AD3
BCF STATUS, RP0 ; Select bank 0
BSF STATUS,6 ;BANK3
BCF EECON1,7 ;Data memory on.
BCF STATUS,5
BCF STATUS,6 ;BANK0 return
CLRF STATUS ; Do initialization, Select bank 0
CLRF INTCON ; Clear int-flags, Disable interrupts
CLRF PCLATH ; Keep in lower 2KByte
CLRF PORTD ; ALL PORT output should output Low.
CLRF PORTB
MOVLW .127 ;Set intial central settingd for motors
MOVWF Result1
MOVLW .127
MOVWF Result2
MOVLW .127
MOVWF Result3
MOVLW .127
MOVWF Result4
CALL DELAY1
CALL LCDINIT ; Initialize LCDisplay
;program start
BEGIN
;Call TABLE_MSG2
;Call DELAY1_P
;Call LCDCLEAR
MOVLW B'01000001' ;Select chan 0 and start conversion
MOVWF ADCON0
CALL DELAYANA
BSF ADCON0.GO
WAIT_CH0 BTFSC ADCON0,GO
GOTO WAIT_CH0
MOVFW ADRESH
CALL EXCH1 ; swap last result with new one
CALL TRANSMIT1
MOVWF BIN
Call BIN2BCD
MOVLW 00H
CALL LCDSDDA ; Position cursor leftmost on first line
MOVFW Hundreds
CALL LCDPUTCHAR
CALL DELAY1
MOVLW 0X001
CALL LCDSDDA
MOVFW Tens
CALL LCDPUTCHAR
CALL DELAY1
MOVLW 0X002
CALL LCDSDDA
MOVFW Ones
CALL LCDPUTCHAR
CALL DELAY1
CLRF ADRESH
TRANSMIT1
MOVFW PREAMBLE
MOVWF TXREG
BTFSC STATUS,TXIF
MOVFW MOTOR1
MOVWF TXREG
BTFSC STATUS,TXIF
MOVFW Result1
MOVWF TXREG
BTFSC STATUS,TXIF
RETURN
I know the servo controller works because it works fine with the PC test program. The osciliscope also tells me that the signals are being generated, what I do see however is that at the servo signal pin there is no change in the signal duration?
HELP!
