I have a piece of code that I am wondering if i could get some help on. I am using visual basic to write a program to control the usb servo controller 6 servo I do not need a complicated script, just something to tell it to go up and pause indeffinitely at a certain position if a button is clicked. Basically i have 2 buttons, one is always activated, when i activate the second i want it to move to about 120 degrees and hold that position until the other button is clicked. Here is the code that I have gotten from here:
SerialPort1.Open()
Dim buffer As Byte() = {128, 1, 0, 12, 79}
SerialPort1.Write(buffer, 0, 5)
From what i understand, the second number in the first string is the device number, or servo number, and the last number is the speed? And then the ‘5’ under the buffer is how long it stays in that position? Any help would be great! And if it could be explained which piece is which that would be great also.
