Hi All,
Can anyone help? I have the bellow code which does work except that in process_received_byte instead of looking for single charaters (“L”) on the RX and sending the correct response ("&L0202") I want to look for the the correct command string ("@L\n") and then send the correct response ("&L0202") only if the correct command string is in the RX buffer.
#include <avr/io.h>
#include <pololu/orangutan.h>
#include <math.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include <pololu\OrangutanSerial\OrangutanSerial.h>
// receive_buffer: A ring buffer that we will use to receive bytes on PD0/RXD.
// The OrangutanSerial library will put received bytes in to
// the buffer starting at the beginning (receiveBuffer[0]).
// After the buffer has been filled, the library will automatically
// start over at the beginning.
char receive_buffer[32];
// receive_buffer_position: This variable will keep track of which bytes in the receive buffer
// we have already processed. It is the offset (0-31) of the next byte
// in the buffer to process.
unsigned char receive_buffer_position = 0;
// send_buffer: A buffer for sending bytes on PD1/TXD.
char send_buffer[32];
// wait_for_sending_to_finish: Waits for the bytes in the send buffer to
// finish transmitting on PD1/TXD. We must call this before modifying
// send_buffer or trying to send more bytes, because otherwise we could
// corrupt an existing transmission.
void wait_for_sending_to_finish()
while(!serial_send_buffer_empty());
// process_received_byte: Responds to a byte that has been received on
// PD0/RXD. If you are writing your own serial program, you can
// replace all the code in this function with your own custom behaviors.
void process_received_byte (char byte)
switch(byte)
// LRU Response full command = @L\n
case 'L':
wait_for_sending_to_finish();
memcpy_P(send_buffer, PSTR("&L0202\n"), 11);
serial_send(send_buffer, 11);
break;
void check_for_new_bytes_received()
while(serial_get_received_bytes() != receive_buffer_position)
// Process the new byte that has just been received.
process_received_byte(receive_buffer[receive_buffer_position]);
// Increment receive_buffer_position, but wrap around when it gets to
// the end of the buffer.
if (receive_buffer_position == sizeof(receive_buffer)-1)
else
receive_buffer_position++;
void USART_Init(void)
// Set the baud rate to 1200 bits per second. Each byte takes ten bit
// times, so you can get at most 120 bytes per second at this speed.
serial_set_baud_rate(1200);
//Set data frame format:
//Set control register UCSR0C:
// Register Async/sync 7 Databits Even Parity 1 stop bit
UCSR0C = (0<<UMSEL00)|(2<<UCSZ00)|(2<<UPM00)|(0<<USBS0);
//Set control register UCSR0B:
//Enable Transmitter and Receiver
//Register En-TX En-RX
UCSR0B = (1<<RXEN0)|(1<<TXEN0); // |(1<<RXCIE0)|(1<<TXCIE0)|(1<<UDRIE0)|(1<<UCSZ02);
int main()
//Initialize the USART: Set Baud Rate and Frame Format
USART_Init();
// Start receiving bytes in the ring buffer.
//serial_receive_ring(receive_buffer, sizeof(receive_buffer));
serial_receive(receive_buffer, sizeof(receive_buffer));
while(1)
// Deal with any new bytes received.
check_for_new_bytes_received();
