I need to do a project where 3 robots move in a grid to six stations which is shown below. The robots need to go to the stations for 18 times(3 times each station), each time returning to the starting point.(As if collecting 3 packages from each station) as fast as possible. The problem i am facing is that the robots need to communicate among each other serially so that they don’t collide(robot needs to detect another robot nearing it and stop).
I have been thinking about using the master and slave serial program given by you to make them communicate! Like set one robot as the the master other as the slave, but i am confused how i am gonna differentiate between the two slaves(thought about using different delays on slaves). I am using a basic grid program for the movement to the stations using co-ordinates of the points.
#include <iostream>
#include <stdio.h>
#include <windows.h>
*This code came directly from http://www.robbayer.com/files/serial-win.pdf
*Minor modifications for output and 3pi connections by Drew Mangus
using namespace std;
int main()
string com;
cout << "Enter COM port using 'COM#' as the format: ";
cin >> com;
HANDLE hSerial;
hSerial = CreateFile(com.c_str(),
GENERIC_READ | GENERIC_WRITE,
0,
0,
OPEN_EXISTING,
FILE_ATTRIBUTE_NORMAL,
0);
if(hSerial==INVALID_HANDLE_VALUE){
if(GetLastError()==ERROR_FILE_NOT_FOUND){
//serial port does not exist. Inform user.
cout << "Serial port number doesn't exist";
//some other error occurred. Inform user.
cout << "Error of some sort, check the settings (1)";
DCB dcbSerialParams = {0};
//dcbSerial.DCBlength=sizeof(dcbSerialParams);
if (!GetCommState(hSerial, &dcbSerialParams)) {
//error getting state
cout << "Error getting the state";
dcbSerialParams.BaudRate=CBR_9600;
dcbSerialParams.ByteSize=8;
dcbSerialParams.StopBits=ONESTOPBIT;
dcbSerialParams.Parity=NOPARITY;
if(!SetCommState(hSerial, &dcbSerialParams)){
//error setting serial port state
cout << "Error setting the port state";
COMMTIMEOUTS timeouts={0};
timeouts.ReadIntervalTimeout=50;
timeouts.ReadTotalTimeoutConstant=50;
timeouts.ReadTotalTimeoutMultiplier=10;
timeouts.WriteTotalTimeoutConstant=50;
timeouts.WriteTotalTimeoutMultiplier=10;
if(!SetCommTimeouts(hSerial, &timeouts)){
//error occureed. Inform user
cout << "Error of some sort, check the settings (2)";
/****************Code for 3pi begins here********************/
char tempbuff[10];//for use in input
char UI;
char forward[5] = {0x02,0x00,0x00,0x01,0x03};
char backward[5] = {0x02,0x00,0x00,0x02,0x03};
char left[5] = {0x02,0x00,0x00,0x03,0x03};
char right[5] = {0x02,0x00,0x00,0x04,0x03};
char point[7] = {0x02,0x00,0x02,0x05,0x00,0x00,0x03};
//int i = 0;
//char szBuff[4] = {0x01,0x80,0x01,0x81}; //Command that you wish to send
DWORD dwBytesRead = 0;
while(UI != 'e'){
printf("Type WASD followed by Enter to move the robot. p to use coordinate positions or type e to exit\r\nCommand: ");
gets(tempbuff);
sscanf(tempbuff,"%c",&UI);
switch(UI){
case 'W':
if(!WriteFile(hSerial, forward, 5, &dwBytesRead, NULL))
printf("Write failed"); //error occurred. Report to user.
break;
case 'A':
if(!WriteFile(hSerial, left, 5, &dwBytesRead, NULL))
break;
case 'S':
if(!WriteFile(hSerial, backward, 5, &dwBytesRead, NULL))
break;
case 'D':
if(!WriteFile(hSerial, right, 5, &dwBytesRead, NULL))
break;
case 'w':
break;
case 'a':
break;
case 's':
break;
case 'd':
break;
case 'p':
int xcor[10], ycor[10];
int w, m, n;
printf("Enter the number of waypoints you want: \r\n");
gets(tempbuff);
sscanf(tempbuff,"%i", &w);
printf("Enter the point X Y hitting enter in between each number: \n");
for(m=0;m<w;++m)
gets(tempbuff);
sscanf(tempbuff,"%i", &xcor[m]);
gets(tempbuff);
sscanf(tempbuff,"%i", &ycor[m]);
for(n=0;n<w;++n)
point[4] = (char)xcor[n];
point[5] = (char)ycor[n];
if(!WriteFile(hSerial, point, 7, &dwBytesRead, NULL))
break;
default:
//Chances are if it got this and you didn't enter an incorrect value it picked up a \n (carriage return) in the buffer.
printf("Error, input did not match a correct value\r\n");
break;
Could you please advise how i should approach this project…and how should i get a start!
