I have problem when I sent the code to Serial 8-Servo Controller under Pololu mode, seems servo not move to position right away I need keep sending until the position I willing to do… how can I do ust sending one code then servo move right away without stop
thank you
This is an odd problem, if you do nothing but send the servo a position command it should go there as fast as it can. Could you describe your control setup (possibly with a wireing diogram/description) and post the code you’re using to try to control the servo? Also, what kind of servo are you using. It shouldn’t really make a difference, but just out of curiosity.
problem solve I do the backward for wiring… stupid me…
