NOOB here, go easy on me!
Using Pololu Maestro micro 6 and referring to manual section 6.c Sample Scripts I can easily copy and paste in the “Using a button or switch to control servos” script. Works perfectly.
NOW, I need to integrate a sequence I created by capturing frames and adjusting durations in the Maestro Control Center’s “Sequence” tab. Simple, but I’m screwing it up!
Can anybody see the simple mistake I have in this script that is attempting to run the sequence once upon button push? TIA!
Here it is:
goto main_loop # Run the main loop when the script starts (see below).
# This subroutine returns 1 if the button is pressed, 0 otherwise.
# To convert the input value (0-1023) to a digital value (0 or 1) representing
# the state of the button, we make a comparison to an arbitrary threshold (500).
# This subroutine puts a logical value of 1 or a 0 on the stack, depending
# on whether the button is pressed or not.
sub button
0 get_position 500 less_than
return
# This subroutine uses the BUTTON subroutine above to wait for a button press,
# including a small delay to eliminate noise or bounces on the input.
sub wait_for_button_press
wait_for_button_open_10ms
wait_for_button_closed_10ms
return
# Wait for the button to be NOT pressed for at least 10 ms.
sub wait_for_button_open_10ms
get_ms # put the current time on the stack
begin
# reset the time on the stack if it is pressed
button
if
drop get_ms
else
if drop return endif
endif
repeat
# Wait for the button to be pressed for at least 10 ms.
sub wait_for_button_closed_10ms
get_ms
begin
# reset the time on the stack if it is not pressed
button
if
else
drop get_ms
endif
repeat
# An example of how to use wait_for_button_press is shown below:
# Uses WAIT_FOR_BUTTON_PRESS to allow a user to step through
# a sequence of positions on servo 1.
main_loop:
begin
#not sure how to put in my "Sequence_0" here
repeat
sub Sequence_0
1 servo
return
#mystuff
# Sequence_0
begin
500 0 6000 0 0 0 frame_0..4 # Frame 0
500 3982 frame_1 # Frame 1
500 7970 frame_1 # Frame 2
500 7384 frame_1 # Frame 3
500 6240 frame_1 # Frame 4
500 5067 frame_1 # Frame 5
500 3968 frame_1 # Frame 6
500 5918 frame_1 # Frame 7
repeat
sub frame_0..4
4 servo
3 servo
2 servo
1 servo
0 servo
delay
return
sub frame_1
1 servo
delay
return
