Sequence cannot trigger DF mini player
I am attempting to trigger a DF mini player with a maestro six channel. I have output selected, but the only way I can trigger it is if I either toggle the enable checkbox on and off, or I swipe the slider back-and-forth really quick. If I add it to a sequence, I cannot get it to trigger. It’s like the DF mini player needs a certain jolt pass the trigger point and the sequence can’t seem to trip it.
Thanks!
KP
Hello, KP.
It sounds like you are referring to the DFPlayer Mini MP3 Module; if that is the case, can you clarify which pin(s) you are connecting to? Also, could you post some pictures of your setup that show all of your connections as well as a copy of your Maestro settings file? You can save a copy of your settings file from the “File” drop-down menu of the Maestro Control Center software while the controller is connected.
Hi Brandon,
Ok so I figured it out. With the channel set to output, I actually have to hold that pin HIGH at its normal state. Then Drop it down to LOW for 50 milliseconds. Then the Little MP3 will trigger. I had it set up the opposite way. This little mp3 player seems to have a sweet spot to trigger.
Thank you,
KP
