I have a stream in the garden and I need to monitor the depth of it, as it can rise quite quickly when heavy rain occurs, and if it goes above a certain level, that’s bad news.
Because of the flow rate at times, I am thinking that the sensor will have to be inside a vertical pipe for protection, as items as large as a railway sleeper have been known to be carried down, and the speed at peak spate is close to 2 Mts/sec, so it’s fast,
The channel is 1 Mtr deep, and it can come out of it’s channel by up to 700 mm onto an overflow area before it becomes a serious problem, so I need to be able to measure up to 1.7 Mtrs depth. The rate of change will be relatively slow, even if a large object blocks the grid, causing a major backup of flow, the rise to 1 M will take a few minutes, and above 1 Mtr, it will depend on the flow rate, as it’s into overflow mode at that stage,
I’m not sure what the best sensor to use will be, I’ve looked at Infra Red and Ultra Sonic, but I have no experience in these areas, so things like side lobes are an issue that I don’t know how to deal with. I did wonder if I could use something as simple as a set of resistors in series with an exposed pole, but I suspect that contamination from the water quality will degrade it quite quickly, and unless I use AC current, Electrolysis could be an issue.
If necessary, I can put a float into the pipe so that there is something other than water to detect. I don’t need to resolve to better than 2.5 cm, and the change rate is not essential, the main thing is to be able to get a reliable depth indication, there will be more than one sensor, as I need to be able to detect that rubbish or a large item has blocked the grid, as that causes a significant differential in depth between before and after the grid, and I also want to be able to highlight when the level is high because of volume of flow.
Plan will be to feed back to a computer that will also be tied into a weather station, and over time, this should allow me to correlate depth against rainfall, as well as have a warning system for blockages or high flow volumes.
So, has anyone any suggestions. A float system based on the car fuel tank sensor concept isn’t likely to work, as I need too big a height operation, and the float arm will be too susceptible to damage. Optical sensing may be a problem, as this is very much an outdoor application, and keeping windows clean on a sensor could be problematic.
Any and all suggestions appreciated
Steve
