hi,
I made a project to log Voltage every millisecond with timestamp (DS3231) using ESP32, but i am getting data every 10 millisecond after some time the logging speed is reducing as time elapses . how to keep same logging speed throughout the process .
this is my code:
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#include "RTClib.h"
#include <Wire.h>
float volt1,volt2;
float offset =0;
RTC_DS1307 rtc;
void writeFile(fs::FS &fs, const char * path, const char * message){
//Serial.printf("Writing file: %s\n", path);
File file = fs.open(path, FILE_WRITE);
if(!file){
Serial.println("Failed to open file for writing");
return;
if(file.print(message)){
Serial.println("File written");
} else {
Serial.println("Write failed");
file.close();
void appendFile(fs::FS &fs, const char * path, const char * message){
//Serial.printf("Appending to file: %s\n", path);
File file = fs.open(path, FILE_APPEND);
if(!file){
// Serial.println("Failed to open file for appending");
return;
// Serial.println("Message appended");
} else {
//Serial.println("Append failed");
file.close();
void setup(){
Serial.begin(115200);
if(!SD.begin()){
Serial.println("Card Mount Failed");
return;
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (!rtc.isrunning()) {
Serial.println("RTC lost power, lets set the time!");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
writeFile(SD, "/MC02.txt", "Feeder Current \r\n");
void loop(){
float volt = analogRead(A0);// read the input
double voltage = map(volt,0,1023, 0, 2500) + offset;
voltage /=100;
volt1=voltage-5;
volt2=volt1*800;
String dataString = "";
DateTime now = rtc.now();
dataString += String(now.day(), DEC);
dataString += "/";
dataString += String(now.month(), DEC);
dataString += "/";
dataString += String(now.year(), DEC);
dataString += ",";
dataString += String(now.hour(), DEC);
dataString += ":";
dataString += String(now.minute(), DEC);
dataString += ":";
dataString += String(now.second(), DEC);
dataString += ",";
dataString += String(voltage);
dataString += ",";
dataString += String(volt2);
dataString += "\r\n";
Serial.println(dataString);
appendFile(SD, "/MC02.txt", dataString.c_str());
