Thanks for all the help, i’m sure this is becoming tiring, I just don’t want to make another “Fallentine” mistake. I tend to buy stuff that either gets to boring to fast, or it just doesn’t live up to the hype.
Each of the drive motors i’d be using are rated for 600mA max at 5v.
I don’t think needing more powerful controllers will be necessary. And i may upgrade to some 1A motors.
Ok you guys are in line with Arduino it seems, and just so i’m not registering for yet another forums.
What about
robotshop.us/arduino-usb-mic … board.html
AND
robotshop.us/adafruit-motor- … duino.html (I’m fairly good at soldering.)
Along with either a DIY or pololu RS-232 to TTL converter.
Will i be able to attach a Micro 8 Servo Controller up to the arduino duemilinove to expand how many servo’s i can use?
And more importantly, can i control my bot on the fly over serial?
I’m sure i’ll get into more complicated programming eventually, but i need the instant gratification of starting up roborealm or microsoft robotics studio, and within an hour having a robot that moves by WASD.
As for the Single line RC motor controllers.
lynxmotion.com/Product.aspx? … egoryID=10
The voltage limit is a little low, but it’s still what my motors need.
Edit:
Choices, choices choices…
Pololu 8 servo controller and serial motor controller = $52
SSC-32 and 2 RC motor controllers = $80 (ouch)
Arduino Duemilinove + Motor Shield Kit = $40. And possible $20 for pololu micro 8 servo board for future expansions.
If i can command the Arduino on the fly over serial, i’ll get that.
If not, probably the Pololu servo controllers.
The SSC-32 setup is just to expensive.Even if the 2 RC motor controllers together cost $20 less than a Dual Rc motor controller.
Heres the platform i want.
robotshop.us/robotshop-rover … kit-5.html
and the pan/tilt i want.
robotshop.us/lynxmotion-pan- … nium2.html
That’s the only 2 definites i have right now.
Edit: Ok to make the RS-232 to TTL converter i need a 4.7Kohm resister, a 10kohm resister, but what transistor do i need?
What is a Q1 2N2222? I dont even know where to find one. (I should take appart this broken radio i got.)
