On a double shaft gearmotor, Does the RPM spec refer to the motor shaft ?
Hello, Yanko.
Our RPM specification is for the output shaft of the gearbox, so to get the RPM of the motor’s extended back-shaft, you can multiply the RPM spec by the gear ratio.
-Derrill
