I have a Craftsman riding mower that I’m making into RC. I have everything working except the remote start and shutdown of the engine. This is the wiring diagram of my ignition switch, so if I put jumper cables in B+A1, it goes into run mode, and to start the engine, I just need to jump S+B+A1.
So if I connect this relay to S+B, can I start and stop the engine?
We cannot help you integrate the RC switch into your mower’s starter, but in general, the relay board can be used to make and break a physical connection between two points in a circuit with an RC signal.
Also, please note that we do not recommend our products be used in applications where their failure could result in injury or significant property damage.
