I’d like to write a packet sniffer for a device I don’t know the protocol of. I know the frequencies and data transmission rates though, so I thought that simply dumping every byte that’s received might help me to understand the protocol. I know that the Wixel comes with a radio_sniffer app, but I’d like to understand better how the radio works and in particular don’t want to rely on the assumed packet logic in there (which of course is perfect for most applications, but not ideal when you simply want to dump everything and for example don’t even know whether the packet length is encoded in the first byte of the packet).
However, I can’t even get the very simple example below to receive anything at all. It doesn’t use interrupts or DMA transfers and I’m really stumped as to why RFTXRXIF is never asserted. It’s inspired by the simple test code here, so I would hope that it’s not completely wrong. But it doesn’t even receive a single byte. The standard radio_sniffer app works fine though, meaning that it does receive something, thus I’m sure it must be an error in the code. I’ve marked the registers I’ve changed w.r.t. radio_sniffer app below with “(!)”. Any help much appreciated!
#include <cc2511_map.h>
#include <board.h>
#include <usb.h>
#include <usb_com.h>
#include <stdio.h>
#include <string.h>
#include <ctype.h>
// The RFST register is how we tell the radio to do something, and these are the
// command strobes we can write to it:
#define SFSTXON 0
#define SCAL 1
#define SRX 2
#define STX 3
#define SIDLE 4
void putchar(char c)
usbComTxSendByte(c);
char nibbleToAscii(uint8 nibble)
nibble &= 0xF;
return (nibble <= 0x9) ? ('0' + nibble) : ('A' + nibble - 0xA);
void main()
unsigned counter;
systemInit();
usbInit();
// Transmit power: one of the highest settings, but not the highest.
PA_TABLE0 = 0xFE;
// Set the center frequency of channel 0 to 2403.47 MHz.
// Freq = 24/2^16*(FREQ[23:0]) = 24/2^16*(0x642500) = 2403.47 MHz
FREQ2 = 0x64;
FREQ1 = 0x25;
FREQ0 = 0x00;
// Note: We had to modify MDMCFG1 from the settings given by
// SmartRF Studio to be compatible with the datasheet.
// (NUM_PREAMBLE should be 8 at 500 kbps and having it be high is a good idea in general).
// MDMCFG1.FEC_EN = 0 : Disable Forward Error Correction
// MDMCFG1.NUM_PREAMBLE = 100 : Minimum number of preamble bytes is 8.
// MDMCFG1.CHANSPC_E = 11 : Channel spacing exponent.
// MDMCFG0.CHANSPC_M = 0x87 : Channel spacing mantissa.
// Channel spacing = (256 + CHANSPC_M)*2^(CHANSPC_E) * f_ref / 2^18
// So the center of channel 255 is
// 2403.47 + 255 * ((256 + 0x87)*2^(3) * 24/2^18) = 2476.50 MHz
// NOTE: The radio's Forward Error Correction feature requires CLKSPD=000.
MDMCFG1 = 0x43;
MDMCFG0 = 0x87; // Modem Configuration
// Controls the FREQ_IF used for RX.
// This is affected by MDMCFG2.DEM_DCFILT_OFF according to p.212 of datasheet.
FSCTRL1 = 0x0A; // Frequency Synthesizer Control
FSCTRL0 = 0x00; // Frequency Synthesizer Control
// Sets the data rate (symbol rate) used in TX and RX. See Sec 13.5 of the datasheet.
// Also sets the channel bandwidth.
// We tried different data rates: 375 kbps was pretty good, but 400 kbps and above caused lots of packet errors.
// NOTE: If you change this, you must change RSSI_OFFSET in radio_registers.h
MDMCFG4 = 0x1D; MDMCFG3 = 0xDE; // Modem configuration (data rate = 350 kbps, bandwidth = 600 kHz).
// MDMCFG2.DEM_DCFILT_OFF = 0, enable digital DC blocking filter before
// demodulator. This affects the FREQ_IF according to p.212 of datasheet.
// MDMCFC2.MANCHESTER_EN = 0 is required because we are using MSK (see Sec 13.9.2)
// MDMCFG2.MOD_FORMAT = 111: MSK modulation
// MDMCFG2.SYNC_MODE = 000: No preamble/sync threshold, for sniffing (!)
MDMCFG2 = 0x70; // Modem Configuration
//DEVIATN = 0x00; // Modem Deviation Setting. No effect because we are using MSK.
// See Sec 13.9.2.
FREND1 = 0xB6; // Front End RX Configuration (adjusts various things, not well documented)
FREND0 = 0x10; // Front End TX Configuration (adjusts current TX LO buffer, not well documented)
// F0CFG and BSCFG configure details of the PID loop used to correct the
// bit rate and frequency of the signal (RX only I believe).
FOCCFG = 0x1D; // Frequency Offset Compensation Configuration
BSCFG = 0x1C; // Bit Synchronization Configuration
// AGC Control:
// This affects many things, including:
// Carrier Sense Absolute Threshold (Sec 13.10.5).
// Carrier Sense Relative Threshold (Sec 13.10.6).
AGCCTRL2 = 0xC7;
AGCCTRL1 = 0x00;
AGCCTRL0 = 0xB2;
// Frequency Synthesizer registers that are not fully documented.
FSCAL3 = 0xEA;
FSCAL2 = 0x0A;
FSCAL1 = 0x00;
FSCAL0 = 0x11;
// Mostly-undocumented test settings.
// NOTE: The datasheet says TEST1 must be 0x31, but SmartRF Studio recommends 0x11.
TEST2 = 0x88;
TEST1 = 0x31;//0x31;//0x11;
TEST0 = 0x09;//0x09;//0x0B;
// Packet control settings.
//PKTCTRL1 = 0x04;
//PKTCTRL0 = 0x45; // Enable data whitening, CRC, and variable length packets.
PKTCTRL1 = 0; // No address checks, no append (!).
PKTCTRL0 = 0x01; // No whitening, no CRC checks, variable length packets (!).
// MCSM.FS_AUTOCAL = 1: Calibrate freq when going from IDLE to RX or TX (or FSTXON).
MCSM0 = 0x14; // Main Radio Control State Machine Configuration
MCSM1 = 0x05; // Disable CCA. After RX, go to FSTXON. After TX, go to FSTXON.
MCSM2 = 0x07; // NOTE: MCSM2 also gets set every time we go into RX mode.
//IEN2 |= 0x01; // Enable RF general interrupt (!)
//RFIM = 0xF0; // Enable these interrupts: DONE, RXOVF, TXUNF, TIMEOUT (!)
//EA = 1; // Enable interrupts in general (!)
PKTLEN = 0xFF; // Set max variable packet length (!).
CHANNR = 0; // Set radio channel.
//S1CON |= 3; // Disabled because we don't use the RF general interrupt (!).
RFST = SRX; // Switch radio to RX.
for (counter = 0; ; ++counter) {
boardService();
usbShowStatusWithGreenLed();
usbComService();
// Signal that we're still alive.
if ((counter & ((1u << 20) - 1)) == 0) {
LED_RED(1);
putchar('.');
putchar('\r');
putchar('\n');
} else {
LED_RED(0);
if (RFTXRXIF) { // Attempt to read packets.
uint8 byte;
RFTXRXIF = 0;
byte = RFD;
putchar(nibbleToAscii(byte >> 4));
putchar(nibbleToAscii(byte));
putchar('\r');
putchar('\n');
Cheers,
squid
