Is it possible to reverse a servo’s direction within the control center? I have four servos connected to a single channel on the radio. I need two of the servos to move in one direction and the other two to move in the opposite direction. Is there a way to achieve this?
Thank you
It sounds like you might be talking about using the signal from your RC receiver as an input to the Maestro and having the Maestro process it to reverse the direction of two of the servos; if that is the case, please note that the Maestro cannot accept RC signals as inputs. One option could be to program a microcontroller like an Arduino or one of our Arduino-compatible A-Star programable controllers to do that. Alternatively, you might consider something like this Servo Travel Reverser from ServoCity with a couple Y-splitter cables.
